  • Guests: 57
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Flyback driver powersupply question
Dragon64
Wed May 30 2012, 09:11AM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
I'm currently trying to build the pulsed flyback driver that jmartis2 (Dr.Dark Current) posted, and am having problems with planning and creating a suitable powersupply.
Schematic http://www.volny.cz/jmartis/qrv4_en_final.png
Currently, I have a heavy iron core power transformer that has a center tap for ground and two 28.7V not current limited. (Though checking the actual voltage on the power supply indicated that it was roughly 1.4V higher then the recorded without load in the following pictures below)
Would it be unsuitable to use multiple LM317 from a rectified and filtered for driving the driver due to the amount of power needed to be dissipated by LM317?
Or would there be a better solution to regulate the power for the driver using given transformer?
1338369000 1438 FT0 Dsc00773
1338369000 1438 FT0 Dsc00774
Wed May 30 2012, 11:30AM
Hi there Hydralisk,
LM338 is a 5A version of LM317T, but if 5A is not enough, using LM317T with a pass transistor/s is the usual way to solve your problem.
If you Google for LM317T Pass transistor you will find plenty of circuit diagrams and constructional details.
Pinky's Brain
Wed May 30 2012, 02:22PM
I don't understand what you're getting at ... only the UC3844 needs a regulated supply, and it can take up to 30 volt so there doesn't need to be a large voltage drop across the regulator.
The supply going to the flyback primary doesn't need to be regulated at all, just needs a rectifier and a smoothing capacitor.
Dragon64
Wed May 30 2012, 10:45PM
Pinky's Brain wrote ...
If the supply to the flyback does not need to be regulated, would this schematic be suffice?
1338417891 1438 FT139172 Flybackpsuv2
Pinky's Brain
Wed May 30 2012, 11:14PM
As long as the jump above C1 becomes an intersection, sure :)
Dragon64
Thu May 31 2012, 12:14AM
Oh whops, I didn't see that there angry
Pinky's Brain
Thu May 31 2012, 03:48PM
Oops, I just realised ... the 220 uF capacitor is off by a factor of around a 100, it needs to be much larger for a reasonable ripple at 8 amps average current draw.
Thu May 31 2012, 04:00PM
Also the resistors for the LM317 are too small. The one that is 15 ohms should be 200, and the one that is 200 ohms should be 200*200/15.
Edit: Actually it might work, I've just never seen them as small as that smile
Dragon64
Fri Jun 01 2012, 01:09AM
Corrected schematic
(Went with the 200ohm just to be on the safe side, according to Steve)
1338512950 1438 FT139172 Flybackpsuv3
