  • Guests: 54
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Are IRF540A's suitable for the Mazilli ZVS circuit?
Ash Small
Fri May 18 2012, 09:26PM Print
I picked up some IRF540A's today at Maplins to play with, but was wondering if they are suitable for a 12V Mazilli circuit.
they are 100V, 28A. One question I have is whether the freewheeling diodes are fast enough.
Datasheet here:
]n10ah_irf540a.pdf[/file]
Fri May 18 2012, 09:28PM
Looks like they should work... below the maximum RDS-On and voltage overhead looks fine ^^
Ash Small
Fri May 18 2012, 09:41PM
And do I need to use zeners if I'm only using a 12V supply?
Fri May 18 2012, 10:08PM
ive only made 1 ZVS but id throw it in there for safety c:
Ash Small
Fri May 18 2012, 11:28PM
I think all I have in the parts bin are a couple of 15V zeners.....
Fri May 18 2012, 11:53PM
i would think anything under the maximum gate voltage would do
genious 7
Sat May 19 2012, 02:07AM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
You'll be safe without zeners on a 12v supply; I have tried it. However, I'd place those 15v zeners just in case one day you forget you built it without them and crank the voltage.
