  • Guests: 30
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
How do you remove your MOT seconderys without damaging them
brandon3055
Wed May 16 2012, 07:12AM Print
I have just finished my third MOT rewind but the last two I decided to try to save the secondary because it is a grate source of copper wire for anything from lits wire to small (not to small) tc secondarys the only problem is removing them without damaging them or the core is a pain in the A!!!!!S so dose anyone now a better wsy. ?
Also dose anyone now of anything that can be used as a quick and easy secondary former rather then carving one out of a price of wood.?
Wed May 16 2012, 08:41AM
To take the MOT core apart, there is really only using a angle grinder to cut the welds open on the sides. This should leave the core relatively unharmed.
The wire from the secondary is a rather large gauge compared to the length wound on a MOT, it is really not suitable to use for a Tesla coil secondary unless you aim for MHz resonance. The varnish on the wire is also some hard splintering not very nice stuff to work with.
If you want to source cheap wire for secondary coils, look for small motors, solenoids or larger industrial relays, the solenoids in these will contain nicely would up on a roll copper wire ready to roll off its form.
Sewage pipe is always a hit, made from hard PVC and if you are lucky you can find scrap pieces near road work. Do not use wood as secondary form as carbon tracks will quickly evolve from the slightest flash over between windings and will render your secondary useless.
brandon3055
Wed May 16 2012, 09:10AM
Sorry I wasn't very clear on that the question is what is the easiest way to remove the secondary from an MOT without damaging it spicificly overcining the problem with the glue (dam glue) the tc was just an example of one of the hundreds of things you could do with the wire
And the former is to wind a new MOT secondary on before transferring it to the MOT core
cbfull
Wed May 16 2012, 03:31PM
When I was building my VTTC I ran into a similar problem. I wanted to use a MOT to power it but I was afraid the MOT secondary voltage would blow the 811A vacuum tubes, I wanted to run it in full-rectified mode which would have put around 1600 volts through the tubes, which probably would have blown them.
I ended up setting the MOT on a hotplate on a low setting for an hour, and kept nudging the heat up until the varnish softened. At that point the sec wire was easy to peel out of it. I was careful to go turn by turn so I would not damage the remaining windings. It took about two hours or less. It worked wonderfully.
brandon3055
Wed May 16 2012, 09:49PM
I tried heating mine up with My blow torch but that would be a far better aproch I will have to give it a go.
This one was not easy to get off but i have had countless uses for it so it was well worth it
1337204993 4548 FT138476 Imag0380
Thu May 17 2012, 07:56AM
Interesting hack, thanks guys.
Down at the scrapyard I saw a guy harvesting parts from microwaves.
He gave me the diodes though smile
Wonder what he is doing with them?
Probably saving the copper for scrap..
