  • Guests: 44
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Hi-Power ZVS Wireless energy transfer (up to 60W on coil!)
Dri0m
Tue May 08 2012, 11:58AM Print
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
Because i was bored, and i've had working ZVS ( :D ), i've decided to try to use ZVS as a WET. The results are nice:
Primary coil is 5+5 turns, secondary coil is 5 turns, 25 turns and 80 turns. ZVS is oscillating at 26.66kHz and running on 24V 8A.
Coil distance 1cm, 4.6A 15V
1cm
Distance 5cm, cca 2A<br>
5cm
25cm, coil 25t
25cm
40cm, coil 80t, LEDs are running on full power<br>
40cm
55cm, LEDs are running on half power<br>
55cm
I'm satisfied with this for few next months :)
radhoo
Fri May 11 2012, 12:59PM
If you want to improve the distance, you will need bigger coils. For my variant I used relatively small coils as well: Link2
300x226
Dri0m
Fri May 11 2012, 01:13PM
radhoo wrote ...
nope, i know the better way:
- Increase frequency
- Make bigger coil
- Use larger cap
and of course, run on higher voltage, maybe 100Volts if i get transformer and ZVS that will work for that voltage :)
Sat May 12 2012, 08:07PM
I think B&Q still have that hollow brass tube for sale.
Would be ideal for this, just pump liquid through the tube to stop it from melting.
-A
Sun May 13 2012, 08:53PM
nice, i need to get round to making one of these, after all my thousends of other projects that is
