  • Guests: 26
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
7Kw+ PSU
Mon Apr 02 2012, 08:33AM Print
Basicly, the goal of this project is to create a 7Kw or more PSU for everything cheesey
it will have a Variac (Ancient 7.5K.V.A Zenith made in about 1950's id say)
the case is a old JSB Powerlight ~(7ft * 2.5ft * 2ft) and a old NovaMill Black Box ~(2ft *2ft * 1/2ft)
Im also planning a Saturatable Reactor made from to HUGE 24-0-24 to 170v transformers (put in series )
Pictures:
Picking up the Main Case from London (3 hours there and 3 hours back cry )
TXH9bs
Troll Dad got in the way mistrust
UzU89s
7fhcOs
Hkm3ss
ZakWolf
Tue Apr 03 2012, 02:33AM
wow, very nice :)
teravolt
Tue Apr 03 2012, 04:09AM
what was it used for and what are you going to use it for. maby a big tube supply
Tue Apr 03 2012, 08:13AM
hehe, thanks, it was a ould backup powersupply for a block of flats, the last owner taken the battarys for his soler panels, i havent got any tubes to run on it saddly. its more of a "occupy time" project
Mon May 07 2012, 11:37PM
Ok then, updates:
-selling off stuff to buy more parts
-building a decent bridge rectifyer and smoother module for the output that is bypassable for AC instead of DC
-working out how to build current limiting in... saturatable reactor?.. anybody know much about them?
-looking for a servo for the variac, planning to try make the entire project computer controlled potentialy..
Inducktion
Tue May 08 2012, 01:27AM
You could implement current limiting by adding a current sense resistor and an op amp feedback circuit.
Wed May 09 2012, 09:32AM
i have no understanding of such black magic! confused
Pinky's Brain
Wed May 09 2012, 03:04PM
I think he misread your intentions and thought you were making a regulated supply ... instead of just rectifying/smoothing the variac output.
I'd just use a triac to limit the AC current rather than a saturable reactor ... neither of those can limit the current from the DC smoothing capacitor though, which at 50/60 Hz has enough energy to do quite a bit of damage.
Sun May 20 2012, 08:30PM
i want to make a regulated supply indeed
ConKbot of Doom
Sun May 20 2012, 10:52PM
7kw, and just plug it right into your standard household outlet... lucky UKers.
