  • Guests: 29
Gagazet (33)
Chris Cristini (36)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Xenon short arc ballast
haxor5354
Tue May 08 2012, 11:07AM Print
I picked up a pretty large xenon short arc light box this weekend for ONLY TEN DOLLARS amazed
and another a smaller bulb for 2$
the bowl reflectors are prabably worth way more than 10$
the whole unit is cooled by compressed air, and the power connectors are rather BEFFY. could prabably handle up to 200 amps
had no luck trying to power them up so far, i tried a 75W metal halide ballast and a 200W mercury lamp ballast
the closet i've ever got was just a few flashes with a 35W automotive HID ballast.
wikipedia says they need 20 to 50kV to ignite and around 50 volts DC to sustain the arc.
right now im thinking of using a flyback to ignite the arc and use a DC welder to sustain the arc.
would the HV feed back from the flyback kill a IGBT welder?
Pinky's Brain
Tue May 08 2012, 01:55PM
No idea, but keep us updated ... so we know flying glass from an exploding bulb hasn't killed ya :)
PS. the welder would probably need a big inductor or diode string to protect it, is it current controlled?
Tue May 08 2012, 04:28PM
This guy > Link2 < built his own short arc xenon lamp. Check it out, he has a lot of useful information.
hboy007
Tue May 08 2012, 05:55PM
please use some doorknob caps and a sound triggered thyratron to do some nice high speed photography (that's what I'd love to do if I had such a lamp.
haxor5354
Tue May 08 2012, 08:52PM
Pinky's Brain wrote ...
problem is, I don't even have a welder. i have a modified MOT that puts out 24V with 20 amps or so. and a have two 40V 100A diode bricks.
could it work if I put a ballast on the MOT then rectify the output to power the lamp? then again, the starting pulse might kill the rectifier brick :(
Tue May 08 2012, 09:22PM
If you watch the video in the link I posted and the follow up he built a circuit that protects the the high current supply from the HV pulse. You could probably run it at a lower current then it is rated for but I'll bet that it will be no where near the brightness you want or it might not be able to sustain the arc.
haxor5354
Tue May 08 2012, 09:26PM
Nik wrote ...
he didn't post the schematic :(
Forty
Wed May 09 2012, 12:18AM
I used a similar arc lamp in my undergrad research as part of a solar simulator machine. Whole unit was about $10k. The front surface bowl reflectors are probably a couple hundred new, so good find. The bulbs in what I used look similar to yours, and I believe they were started with about 2.2kv. Here's a macro shot of the bulb I took for photo class (most of my shots were from the lab, the non-scientists were not amused.)
1336522524 3888 FT138079 Gresh21
radiotech
Wed May 09 2012, 03:41AM
Our tiny local theater is facing extinction because movie distributors are insisting on digital
projection and current movies won't be available on film. High capital expenditure is required for
the projector approved for the format. This is hard to raise.
Will this mean the lamps, et al, will more and more be available as surplus?
Wed May 09 2012, 07:02AM
haxor5354 wrote ...
It's dead simple, you should be able to figure it out from the video. :p
Hint: It's a Tesla coil, but the Tesla resonator is replaced with a transformer wound on a couple of ferrite rings.
