  • Guests: 38
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Induction heater
Ben Solon
Fri May 04 2012, 04:32PM Print
A friend asked me if I wanted to build a large induction heater with him after seeing my small zvs version. I would like to use my igbts as I have a lot of them. I don't see many people using them though. Igbts have switching losses and assuming 50a and 80khz the losses in the 30n60 equal roughly 300w. If you compare that to mosfets on resistance losses assuming 50a and 170v, the losses are enormous at over a kw. Am I going about this correctly? My aim is to have something in between marko's zvs and Tim Williams monster. 5kw maybe?
The other question is how should I drive it? Igbts don't parrallel well like mosfets do, so should we drive to impedence matching xmfr with a full bridge?
Inducktion
Sat May 05 2012, 04:56AM
You have to remember that an induction heater's tank isn't ever directly coupled to what flows through your switches.
The switches only have to conduct for a short amount of time to achieve resonance. With impedence matching, and inductive matching you can easily achieve ZVS or ZCS and prevent your mosfets from getting excessively toasty.
My induction heater used mosfets; but because of the inductor the actual current the mosfets will see is very low.
Ben Solon
Sat May 05 2012, 03:08PM
how low exactly? and what power was your ih? there is very little info of peoples work with induction heaters beyond 1kw on the internet, and it always helps me to see what works and what doesn't before building something of my own.
edit: i know generally where i want to resonate unloaded, but is there any way to know in advance the amount of current in the tank based on the capacitance and frequency? i know that more capacitance gives a higher current. i am looking at something in between 6.6 and 8.8 microfarads. but i don't want to spend money on a large tank cap, then blow it up...
Sat May 05 2012, 07:41PM
To melt a small piece of steel, you need in the region of 1kW input power and maybe 100 or 200A of work coil current. Search the forum for a thread called "OMG Induction Heater".
Sat May 05 2012, 08:15PM
When you get above 20-30khz the IGBTs will have very large losses and you should use mosfets.
Read this for a tutorial on how to build a unit from 2-12kw. It includes theory and schematics.
You will need between 1-2kw to melt a small steel nut.
Ben Solon
Sat May 05 2012, 09:09PM
steve: thanks for the thread. i read it a long time ago, then forgot the name and couldn't find it again.
iamsmooth: that actually is what i ahve been reeding a lot lately, and while it is the best theory site out there(aside from maybe richies, but its too close to say), it doesnt have too much on the circuit other than the one schematic.
iamsmooth uses fets, tim williams uses igbt's and the guy from the video in "omg induction heater" uses igbt's. i think i may be able to get by using them. i have driven my 30n60's all the way to 1.8mhz and they worked just fine in a class e tc.
i intend to heat some large chunks of iron and steel, so i am going with a low resosnant frequency. 25-60khz. if i am shooting for 3-6kw, what should my tank capacitance be? i am going to buy one of those eurofarads off of ebay.
Sat May 05 2012, 11:24PM
Your coil is going to be a few uH. Using this and your intended frequency range you can figure out what capacitor you need. The inductance of the coil will change with the workpiece, so the frequency is just a ballpark number. Once you settle on a capacitance value you will see what the general frequency range of your tank will be. If it is too high use fets; if it is low enough use the IGBTs.
Ben Solon
Sun May 06 2012, 12:40AM
dont take this the wrong way, but i know this already. its why i said 25-60khz the coil is going to be 1uH and the cap will be 7.5uF. this means it is self resonant at ~60khz and will drop with the added inductance of the work piece. i assume 308A rated tank will be adequate?
one other question though. in your ih what was the resonant rise? my caps are rated for 580V, and i plan on using either 170 or 340 vdc bus. i know that in a mazzilli circuit that the voltage can rise over 3X the supply voltage, but what about in an lclr? what did you use as a bus voltage? your caps could take 750v. i can always use over-voltage cutout, but i want to design a sytem that wont be using that feature often.
thanks for the expertise
Storken
Sun May 06 2012, 12:03PM
Storken Registered Member #1960 Joined: Thu Feb 05 2009, 11:57PM
The mazilli driver raises the voltage by Pi, just to be totally clear on that (I see alot of misunderstanding here).
The lclr setup has constant voltage with sinusoidal (at resonance) current flowing through the tank. I'm building one myself, but I've not gotten it to work yet. Mine uses a microcontroller and a half bridge driver - driving two 80V fets. Hope to be able to work in the 1,5 to 2kW area myself.
Ben Solon
Sun May 06 2012, 05:06PM
yes, but i assumed it was resonant rise that raised the voltege. the lclr is also at resonance, so doesnt that mean that it will also have rise? and what do you mean by constant, because that could mean constant at line input voltage or constant at 20kv.
thanks
