  • Guests: 71
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
Capacitors instead of batteries?
Platinum
Thu May 03 2012, 04:07AM Print
In airsoft you use normally use 8.6v 1000-4000Mah batteries, I've seen a webpage that you can use capacitors, if you use a 8.6v 1600mah battery it normally lasts you a short game in airsoft.
What I want to ask is, are caps better than batteries? in size and performance and how long they last? I don't know the calculations.
Also MOSFET's are being used to reduce trigger response. Although I don't know how, it lowers arcing at the switch contacts. How would install the FET?
2Spoons
Thu May 03 2012, 05:47AM
8.6V 1000mAH is roughly 31,000 joules. To store that in a cap at 8.6V you would need 838 F, assuming you could still extract energy as the cap voltage dropped to zero. Not practical.
The energy density of batteries still far exceeds capacitors, and they have a much friendlier discharge curve.
Thu May 03 2012, 06:21AM
Do I have to say, do some research yourself before making a thread? Link2
Platinum
Thu May 03 2012, 08:27AM
Abandon thread :)
838Farads?
I'm sure this here is being used the same was as battery
Sigurthr
Thu May 03 2012, 09:35AM
That is one TERRIBLE soldering job.
Platinum
Thu May 03 2012, 10:02AM
I'm not an expert solderist :)
But yeah that is a pants job.
Ash Small
Thu May 03 2012, 10:35AM
"Capacitor banks are used to fill in the extra power needed to power your aeg. Think of it as a battery on steroids, As the motor turns, only 50% of the time is it pulling the spring due to the sector gear pulling the piston and releasing it, as the motor pulls the piston it uses more power than when it is not pulling the spring so therefore a capacitor bank aids the motor by supplying it with more power.
You do not need one with a high powered (good) lipo battery as the battery can handle the motors draw."
Sounds like he's using it to try to boost a knackered battery.
Tetris
Thu May 03 2012, 03:43PM
I've seen an ad in Popular Science where they use "ultracapacitors" to power a computer mouse. It seems like an interesting concept, and I think it would catch on because of the less toxic materials needed to make it, and the frequency you would need to dispose of them would be less. Personally, I think ultracaps would be useful for low current things. As far as high current things, I'll leave it to physicists to find an effective dielectric :P
Thu May 03 2012, 04:03PM
Capacitors (including ultracaps) can be excellent power sources for high-current loads at low duty cycles. Typically they are recharged before every shot. Ultracap banks are used in some electric-hybrid city buses.
The airsoft guy is using his caps in parallel with a rechargeable battery.
Like the "boostcaps" people use with stupidly powerful audio amps in cars.
I bet it -does- give an obvious improvement in motor performance,
but engineers and scientists would want to see measurement results.
Dr. Brownout
Thu May 03 2012, 06:09PM
Dr. Brownout Registered Member #2405 Joined: Fri Oct 02 2009, 12:59AM
Actually capacitors have been used as batteries. If you have ever seen those shake charge flashlites that were once so popular they actually used a coil and a magnet, a fullwave bridge and a capacitor. When you shake it the lose magnet was allowed to slide in an out of the coil, the coil output was connected to a full bridge the full bridge fed the caps the caps inturn would discharge through bulb or led which ever type you had, however the efficiencies are obsurdly low. But it did work.
--Brian
