  • Guests: 39
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
180kV high voltage multiplier
kilovolt
Wed May 02 2012, 08:24PM Print
kilovolt Registered Member #2018 Joined: Tue Mar 10 2009, 09:56AM
Dear HV-friends out there wink
Some time ago I built the following multiplier project. The results are not as spectacular as with a tesla coil, but the building- and planning phase of the project was really funny.
Some of the specs first: The latest version of the multiplier contains 13 stages with 16kV each, but I put in only about 14kVss, which is in fact only about 5kV eff, but with rather high current. Output is a hot arc discharge up to about 18cm or some noisy 22cm sparks. The output current is limited by a resistor array of 39 high power resistors in series with 6.8kOhm and 11W resp. 17W each.
Some pictures:
Dsc02972d
Dsc02971c
Dsc03268bq
Dsc03251i
Dsc03093o
Capacitors are cheap ceramic caps, for every cap a serial connection of two 8kV/2nF caps, and then five of these pairs of them paralleled. Diodes are two different types. There are 2CL2FM (20kV/200mA fast recovery) and some micrwave-oven diodes SCL-11Z which I got cheap from an online-auction.
The setup is powered by a royer coverter together with a self made high frequency ferrit HV-transformer. The Royer converter draws about 16A @ 58V.
Dsc02819w
Some low power corona at 100kV in the very first beginning (only a test-setup):
Dsc02711n
Dsc02714jr
Best regards
kilovolt
radhoo
Wed May 02 2012, 08:52PM
Congrats!
Now where will you store that big toy?
kilovolt
Thu May 03 2012, 06:24AM
Thanks!
Good question wink I live in a house and I've got two different work places, so I can let it be for a while as it is, but you're right, the setup is very unhandy, because I didn't want to work with oil insulation. Maybe I will disassemble the multiplier circuit and use the material for future projects. I've done this the same way with several other projects in the past, for examples some of my earlier tesla coils. Saves money and space smile
Best regards
kilovolt
Dri0m
Thu May 03 2012, 01:07PM
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
niiiceee, where did you get that huge ferrite core? :3
kilovolt
Thu May 03 2012, 01:20PM
Thank you, Dri0m smile
A friend gave me the core for free, but I don't know were it was from.
A little movie, unfortunately not from the latest setup, so only 16cm arcs:
Best regards
kilovolt
radhoo
Sat May 05 2012, 10:23AM
kilovolt wrote ...
You can go without oil up to a point, see Link2
kilovolt wrote ...
Not before you take lots of videos and photos cheesey
kilovolt
Sat May 05 2012, 07:08PM
Very nice setup, radhoo! Really handy. Like it! smile Is it all selfmade or from an x-ray-machine?
Best regards
kilovolt
