  • Guests: 31
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
pulse transformer vs other transformers
Mon Apr 30 2012, 06:38PM Print
It is that time of year when I take out my home-built low impedence 10kv electric fence to keep small animals away from my garden.
What is the design difference between a pulse transformer and a general purpose step-up or down transformer? Sulaiman?
Mon Apr 30 2012, 08:48PM
Wikipedia Link2
The term 'pulse transformer' is commonly used in many quite different contexts,
e.g. 'Trigger transformer' for scr etc.
where the transformer passes a pulse - but the waveform is not critical .
To me the main characteristics are tight pri:sec coupling (low leakage flux/inductance)
and basically all of the other properties mentioned in the wikipedia article.
As you referred to an 'electric fence' what do you mean by 'pulse transformer' ?
- trigger transformer for an scr?, step-up transformer? .....
Tue May 01 2012, 12:43AM
The transformer sees a pulsed input from the discharge of a capacitor. I charge a capacitor to 500v and use an SCR to discharge the capacitor through the transformer primary. The secondary voltage is close to 20x the primary voltage. The pulse is a few microseconds in duration.
Alex M
Tue May 01 2012, 12:17PM
Well in this application you would want pulses to give the animals a quick shock, rather than say a MOT which would just fry the animal as soon at it made contact to the fence.
If you shorted out the fences HT output it would not trip the MCB where as the MOT would, which is needed outside where a fallen tree or plant could cause the fence to touch earth.
So I guess you could say your pulse transformer setup is current limited.
Not quite sure what you are asking though.
Tue May 01 2012, 12:33PM
For this application things like waveform integrity, close pri:sec coupling etc. are not important.
The magnetic path can be closed (e.g. 'flyback' core without airgaps) or open (e.g. ferrite rod or bar)
The only two important things are;
1 Insulation. 20 kV insulation is not too difficult for pulses, many small layers for the secondary helps.
........the main concern here will be moisture ingress as the unit will be outdoors. Potting in wax or epoxy or similar would be required.
2 Core saturation, the product of (core area) x (number of turns) should be enough to handle the integral of (V.dt) ... volt.seconds.
....... as few primary turns as possible is best as this requires proportionately less secondary turns.
Alex M
Tue May 01 2012, 03:32PM
Sulaiman wrote ...
I second this. When I made a homemade step-up pulse transformer using nothing but electrical tape for insulation it would work fine but testing it outside in the dark would show that every-time there was a pulse of around 20kV on the output corona was also visible around the transformer at the same time of the pulses. Especially if the output was unloaded, even though it did not arc-over it would probably eventually eat away at the insulation.
This is a homemade one I made running. It was a really crude job but it worked and got me interested in high voltage.
The core is a ferrite rod. Its all wound on a piece of PVC pipe from wickes, secondary coil is lots of turns of 40SWG enamelled magnet wire (one layer) and the primary is a few turns of single cored copper wire from some spare twin and earth mains wire.
Doubt it would last long out in the British weather as a fence energiser though angry
