  • Guests: 299
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
3 bank battery charger repair?
Chip Fixes
Sun Apr 29 2012, 12:28AM Print
Uh I have a 3 bank boat battery charger (Minn Kota MK 330) that got wet and won't turn on so I figured an internal fuse blew. I took out the screws to the front and back panel and pryed the metal off but I was confronted with what looks like concrete. Now what? Link2
radiotech
Sun Apr 29 2012, 03:06AM
Sorry, cant resist.
You could test it in deep river to see if it floats. cheesey
Carbon_Rod
Sun Apr 29 2012, 03:17AM
The device cost is worth less than removing epoxy potting compound and repair.
Try opening the other side to see if it is a solid cast...
Please drop it in the aluminum pile at the recyclers rather then some poor fishes' home...
cheesey
Chip Fixes
Sun Apr 29 2012, 03:51PM
Haha will do. Might cut it open with a sawzall or similar cutting device to see if I can at least get at the transformer. The other side is also solid cast
