  • Guests: 35
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
oscilloscope and GFI
radioman
Sat Apr 28 2012, 11:36PM Print
radioman Registered Member #3026 Joined: Fri Jul 23 2010, 02:46PM
Hi Everyone,
I just got my first oscilloscope. Whenever I use it to look for power supply ripple in an old radio I'm working on, it trips my shop GFI! Why does this happen and how can I avoid it??
Thanks much!
Sun Apr 29 2012, 12:19AM
Many old valve sets had a 'live' chassis (for economy)
due to the direct rectification of line voltage.
Best = power the radio via an isolation transformer and earth the chassis
Good= use two probes as a differential probe
.............. invert channel B, add A+B channels, clip one probe tip to chassis, use the other tip to probe...do not connect the probe earth leads anywhere (un-clip them if possible). The chassis will still be 'live' so take care.
Worst= disconnect the 'scope earth wire from the mains ..very dangerous as now even the 'scope chassis will be live.
radioman
Sun Apr 29 2012, 01:35PM
Thank you, Sulaiman,
I am using a flea market transformer I hope is an isolation transformer -- but it doesn't say "isolation" on it. Can I determine this by measuring the resistance between primary and secondary windings? And what should the reading be?
Thanks again!
Inducktion
Sun Apr 29 2012, 05:24PM
An isolation transformer will output the same voltage on the primary and secondary ends... so plug it in and see how much it outputs. If it's 120 vAc, then you're good.
If not, then it's not an isolation transformer.
sngecko
Sun Apr 29 2012, 09:51PM
sngecko Registered Member #3447 Joined: Fri Nov 26 2010, 11:10PM
[little note]...and a Variac is not an isolation transformer.
Mon Apr 30 2012, 07:05AM
I guess Inducktion is technically correct, since a 1:1 autotransformer is no transformer at all. smile
But it still strikes me as a triumph of logic over safety. If I bought a flea market transformer, I'd rather verify that the primary and secondary were actually isolated from each other and from the core, using a hi-pot tester, or at least an ordinary multimeter on the resistance range.
Whatever the reason, the GFI is probably trying to tell you that your radio isn't properly isolated from the line.
