  • Guests: 84
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Ionizer circuit
HVGuyAFSL
Mon Apr 23 2012, 01:50PM Print
HVGuyAFSL Registered Member #4252 Joined: Fri Dec 09 2011, 10:43AM
Good afternoon guys.
I am developing a circuit for an ionizer. I didn't know that it could be done just by a Cockroft Walton Multiplier circuit. I tried the circuit attached here (with 15 stages) but the relationship between the output and the input is far from linear (only 'til th 5th stage) - see the other attached file (IONIZER.jpg). By the way, the signal in each point is always a sinewave - i thought the diodes would rectify the waveform. Am i measuring it in the wrong way?
1335189056 4252 FT0 Circuito Geral
1335189057 4252 FT0 Ionizer
Mon Apr 23 2012, 10:44PM
keep one leed (the black one on the nuetral) then take the red lead to each point you want to measure.
that sinewave your seeing is needed for the doubling or whatever, if you measure from N to 16, youll see pulsing dc, or DC given your high protection resistance.
and just to remind peeps, there are many voltage multiplier arrangements possible. Some are meant to be better for one purpose and not another, it depends what your after.
Tue Apr 24 2012, 04:52AM
Looks exactly like a 15-stage multiplier kit that I bought....
Mine never worked well, 10nF is too small for 50 or 60 Hz
I intend to replace the 1N4007s with UF4007s and run it at kHz someday
...when I get around to it.
Dri0m
Tue Apr 24 2012, 06:57AM
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
Sulaiman wrote ...
1N4007s have capacitance measured on frequency 1MHZ, so i think they can handle a few kHz
HVGuyAFSL
Tue Apr 24 2012, 07:12AM
Thank you for your comments!
@Sulaiman: so which capacitance should i use? 100nF? I have 33nF - i will try with these.
Tue Apr 24 2012, 06:09PM
I guess the larger the capacitance the better....
One 'ideal' solution is
top stage capacitors = C
next stage down = 2.C
next stage down = 3.C
etc.
uses a lot of capacitors though!
For example, in our case we have 30 capacitors,
that could be re-arranged as
2x1 for the top stage
2x2 for the next
2x3 for the next
2x4 for the next
2x5 for the bottom stage.
This would perform better but with only 5 stages the output would be less than 2 kV
Since you have larger values try combining them with the existing 10nFs as per the above scheme,
higher capacitance in the early/lower stages.
Tue Apr 24 2012, 06:38PM
HVGuyAFSL wrote ...
well you can increase the capacity, increase frequency or better still do both.
HVGuyAFSL
Thu Apr 26 2012, 09:55AM
@Sulaiman: It is something like this right (attached file)? Then i can use 1x33nF to do the job of 3x10nF. Thank you for your help. I'll try this!! How do you know that with 5 of this combined stages the voltage will be less than 2kV?
@Patrick: how do i increase the frequency?
1335434119 4252 FT137452 Ioniser Combination
Thu Apr 26 2012, 04:14PM
No....
the multiples of capacitors are in parallel, not series.
Thu Apr 26 2012, 06:45PM
you need a transistor type driver, that produces a waveform of one kind or another, usually square. but stick with AC from the wall socket for now. It takes time and skill to build a driver. if you need low current the wall socket (properly limited) is fine.
