  • Guests: 44
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Nixie Tube Clock troubles
Inducktion
Mon Apr 23 2012, 03:11AM Print
Hey all,
I've recently tried making a nixie tube clock, and I've ran into some, er, issues. I'm using IN-12B and IN-12A nixies for the project.
I'm using a cell phone charger which provides 6 volts to the logic... Using half wave rectified mains, I measured the nixie getting roughly 160 vDC, through 55k ohms of resistance, which means around 2.8 mA.
However, the nixie fails to light up fully...and I can't figure out why. I'm using 10k ohm resistors to the driving transistors (MPSA42's) , and I've tested the logic to make sure it's all working properly (counting correctly)
If someone could provide some clues as to why the nixie tube isn't working right, please provide them!
Do I need to change the logic supply to 5 volts period? Or, change the base resistors of the transistors?
Thanks!
dude_500
Mon Apr 23 2012, 04:17AM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
Although I don't know Russian, I see the numbers 170V and 200V in the datasheet. I'm guessing absolute min and absolute max. Perhaps it needs a bit more voltage to really glow well. Also, do you have any filtering capacitors on the rectified mains powering the tubes? I'm not sure how nixie's behave on rectified but unfiltered mains.
Also, it's possible the tubes are out of their service life. Nixie tubes do eventually go bad.
Inducktion
Mon Apr 23 2012, 04:18AM
I figured out the issue;
Turns out the logic supply was being noisy as hell, and thus the 1 hz oscillator wasn't oscillating...
Changed it out for a good ol' iron core transformer, and a 5 v regulator, now that works properly.
However, now a new issue as come to show; the tube is being pulsed at a 2 hz interval...something isn't counting correctly. I've got to go back over it again, and verify the connections are right. IF they are, I'll add some decoupling capacitors once I get new solder.
Tue Apr 24 2012, 07:46AM
Nixies with gas can be fixed a la "Electronics World" by putting on a heat spreader ie tinfoil, and oven cooking for 24 hours at 250C.
Carefully ramping temperature up and down at start and end of cooking also will ensure tube doesen't get up to air quickly.
Tried this with a gassy VFD and it worked fine.
Inducktion
Tue Apr 24 2012, 06:31PM
Well, it just needed capacitors. I managed to find a LITTLE bit of solder lying around and put some filter/decoupling caps for the logic supply...No more blinky, it's counting now! :)
I'll probably add a supercap to the board so it keeps time in case power goes out. I've still gotta finish adding the rest of the driving transistors and nixies.
