  • Guests: 46
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
VLF antenna not working
Tetris
Fri Apr 20 2012, 03:37PM Print
Avi had tried to configure SpecLab for me so I could use the antenna for stuff, but he told me it isn't working. I don't know what's wrong with it, and I'd like to know how to fix it without rebuilding the entire thing.
I wound 30awg magnet wire 50 or so times around a 2 foot by 4 foot wooden mount (I tried to get it square but I couldn't). It is connected to a headphone jack which will plug into my computer.
I have no idea how to fix it or what's wrong with it, or even how to find out what is wrong with it. If needed, I will post a video of the antenna (but I can't now because I am in school).
radiotech
Sat Apr 21 2012, 03:59AM
Perhaps you need a preamplifier.
Sat Apr 21 2012, 06:03AM
1) check your pc setup by using a microphone to see the spectrum
2) 50 turns 2' x 4' would make a good antenna for am broadcast radio
...... which will be a MUCH larger signal than any vlf that may be receivable
3) You DEFINITELY need a preamplifier, e.g. Link2
4) You need to either shield the antenna (as in the above link) or make a 'balanced' antenna.
For loads of vlf info have a look here Link2
Sat Apr 21 2012, 08:38AM
Might be worth doing what some guys on the amateur forums did and making your own square antenna.
This can be done by salvaging four long identical ferrite rods, winding the Litz wire onto each leaving a nice tinned tail and then making up a mixture of iron III oxide and epoxy and cementing the rods together with as small a gap as possible and ensuring that the "sense" ends are in phase ie same turn direction.
Connect the wires together but leave one corner open as this is your take-off point.
Also I'd use a Bluetooth headphone as the pickup so the antenna can be located well away from any interfering mains, and wrap the whole antenna in copper or aluminium tape apart from one small slot so it isn't a complete circuit.
EDIT:- And a cantenna to send the signal to a convenient PC etc so it can be solar powered and installed in a tree.
-A
Chris Russell
Sun Apr 22 2012, 12:32PM
Chris Russell ... not Russel!
I've had a little luck with a similar antenna. Most of the really big VLF transmitters don't require a lot of sensitivity. Assuming you're on the west coast, NPM in Hawaii at 21.4 kHz or so should be relatively easy to receive. NAA, in Cutler, Maine, at 24 kHz should be a little harder but doable. PM me or reply here and I'd be happy to take a look at your spectrograms.
Tetris
Sun Apr 22 2012, 07:05PM
Chris Russell wrote ...
I'm in Florida, lol. Uh, the antenna broke and I can't fix it at the moment, but it shows a straight line at 60hz and some other intervals.
Chris Russell
Mon Apr 23 2012, 12:35AM
Ah, then yeah, NAA in Cutler should be a pretty easy catch. NPM is a little more difficult, but they do a series of CW dashes nightly that should be receivable from there.
