  • Guests: 50
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
how do I rotate the anode of x-ray tube?
petersjoe95
Wed Apr 18 2012, 08:24PM Print
petersjoe95 Registered Member #4472 Joined: Wed Apr 18 2012, 01:51PM
Hello, I wasn't sure whether to place this in the high voltage forum or here as I think both apply. So...
I have a Eureka? rotating anode x-ray tube. I won this at an auction a number of years back, but it didn't include the mechanism to rotate the anode. Can I still obtain the circuit/ mechanism or perhaps design something myself?
Thanks, in advance, for your help.
Joe
Adam Munich
Wed Apr 18 2012, 11:30PM
You need to put it in a rotating magnetic field! It's an induction motor.
radiotech
Thu Apr 19 2012, 05:30AM
Otto Glasser et al, Medical Physics 1944
Mention is made of a higher frequency to turn the rotor. I do have a cycle converter that
changes 60 Hz to about 180 Hz, made by Pickering. Could that be its use?
petersjoe95
Thu Apr 19 2012, 02:52PM
Thanks, guys. I think I get the idea, but I'm still not sure how to proceed. It almost seems as if I were to remove the center part of a motor and keep the outside coils intact, and then surround the tube with the coils, I might be able to get it to work but not sure. It may cause the rotor to spin too fast or overload the coils somehow. If it's too complicated, I'll just let the tube as-is as I don't want to destroy it. In my mind, I was picturing something like a grinder motor with the center removed and replaced by the tube. Thanks.
radiotech
Thu Apr 19 2012, 04:54PM
You could fix some small magnets to the inside surface of a cylinder
and arrange a hand wheel attached to a belt to spin it.
Also investigate the rotor end of your tube to determine if any parts
are ferromagnetic.
Could you post some photos of your tube?
Newton Brawn
Sat Apr 28 2012, 12:14AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Yes, Peter post some pictures of the Xray tube. Add a scale for us figure out the diameter of neck .
Remove the rotor of small split pole motor (2 or 4 pole), it will provide the rotating field required to turn the anode. Single phase domestic table fan. Since the rotor is removed, the stator impedance decrease, requiring less voltage supply to avoid overload the mortor coils. 12-25 volts may be the proper voltage to feed a 120V fan.
I understad that you dont want damage the tube, Why dont add a variac keep the anode rotating slow ?
Show the pictures
Regards
Newton
