  • Guests: 67
Best way to get ~380V @ 4 Amps from 120v/240v circuit.
Spaceballs3000
Wed Apr 18 2012, 10:16AM Print
Spaceballs3000 Registered Member #4468 Joined: Wed Apr 18 2012, 09:34AM
Yay finally able to join 4HV! I've been a long time lurker, now feel the need to ask a few questions!
I've picked up a few used AC motor controller and motor (both ~100kw) that I like to do a basic bench test (with my caps I have on hand) to verify basic controls to see if it's still functional. i.e. start motor slowly up (no load), watch wattage usage, when it hits 1200 watts, unplug AC power source. Watch voltage on caps until it hits 300v (low voltage cutoff for motor controller.) Then put motor controller into regen mode and slow/stop motor rotor. Verify voltage on caps goes up.
I'm thinking about doing this setup, and I figured I show what I'm going try to do to see if anyone sees any major mistakes I'm about to do.
I've picked up a this module AIF04ZPFC-02NTL where it will take 240v AC to 380v DC at 1600 watts. I then have 800v 8amp diode inline that connects to my bank of 12 450v 2000uf caps. The diode prevent regen energy from going back to the AC/DC module. From there I connect it to the motor controller. I know I'll likely have to pre-charge my caps, since I don't want to overload the AC/DC module when first turning it on, so I have that covered. Other than pre-charging, monitoring wattage (at AC source), and voltage monitor on
caps, is there anything else I should be doing?
Thanks!
Wed Apr 18 2012, 06:44PM
100kW! was that a typo !? ill
You can use a normal voltage multiplier to get up there but, the PF may get ugly. if so youll need to use an active or passive PFC type system.
i like the FAN4800IN ic which will do it all, though it has a hhigh part count.
Newton Brawn
Thu Apr 19 2012, 03:34AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Spaceballs;
are u going to use the mator as generator ?
Thu Apr 19 2012, 04:45PM
I repair drives almost every week....
I/we usually test a drive using filament lamps before connecting a motor as a fault in the drive could have nasty consequences.
If you give the manufacturer and model number I may be able to help.
Harry
Thu Apr 19 2012, 07:03PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
One option would be to get two 240 - 110 transformers, wire the 110 side of each transformer in series, then wire the 240 side in series, should get around 400 - 440 volts.
teravolt
Thu Apr 19 2012, 09:28PM
a full wave dublier would do. you can turn 120vac into 380vdc or if you use a bridge rectifier and rectifie your 240 and filter it with your caps you will get a better power factor.. I just bought a 1500w 110,220 to 110,220 transformer for isolation purpaces for testing. just remember to use a soft start circuit for the charge or you will get a large inrush and break something.
Spaceballs3000
Fri Apr 20 2012, 12:37PM
Sulaiman: that is a good idea to use the "filament lamps" as current limiter!
At first I was sure that the motor controller will throw a fault as it was expecting a certain minimal load.. but that might not be the case as the motor could already be spinning (i.e. going downhill) before applying power..
FAN4800IN is good idea, agreed part count little to high for me to build right now.
As you may have guess by now, it's AC electric motors. These motors came out of electric bus, I'm planning on putting two of them into a car :) Also 100kw is just it's peak, it's average continuous usage is much lower.
Fri Apr 20 2012, 06:16PM
Spaceballs3000 wrote ...
Ah that makes things abit easier, you can, if PF is a problem use a special type as seen on Steve Wards site. it has a lower part count and can be modded for your purpose.
