  • Guests: 47
A 555 based PWM generator
Kabelnazs
Sun Mar 18 2012, 05:32PM Print
Kabelnazs Registered Member #3436 Joined: Tue Nov 23 2010, 04:12PM
HI :)
MY newest design... works perfect, can be used for H, F bridge projects, Lab stuff u.s.w
Hear the diagram and two pic of Wave forms, first on out C, second between A&B
Frequency maximum for stably work 250-300kHz
1332091816 3436 FT0 Diagram
1332091816 3436 FT0 Photo0298
1332091816 3436 FT0 Photo0302
1332091817 3436 FT0 Photo0314
1332091817 3436 FT0 Photo0307
Kabelnazs
Sun Mar 25 2012, 05:28PM
HI Friends and Comrades :)
And other my newest circuits:)
A Frequency counter to this or other generator [can be used in other schematics... if you have the parts as need], the decade counter K561IE4 http://tec.org.ru/board/k176ie4/149-1-0-788
that i used is a (not full) analog from CD4026 its a Soviet chip:) i have lot`s of them ... so i used that chip^^ "OI" its not so simple as with CD4026 that chip need a extra input gate and if need a count freq > than 999Hz [and wont use 6 decades] in such circuit a extra divider is needed i case :1000 that give us
count from 0 to 999.9kHZ only 4 digit display, works perfect
1332696457 3436 FT135899 Counter
1332696457 3436 FT135899 Photo0320
Kabelnazs
Sun Mar 25 2012, 05:31PM
On the test board is only 3 dig`s, its to small for the 4-one :))) but it`s works
Kabelnazs
Sun Mar 25 2012, 05:48PM
UPS :) i found a bug ^^
The Decimal point of 2 decade must be connected to the GND not VCC :)))
1332697696 3436 FT135899 Counter Mk2
Wed Mar 28 2012, 12:15AM
Kabelnazs wrote ...
this is a great body of work, its good to see someone can still use ASIC's. And that they havent gone the way of the Dinosaurs. Everybody it seems wants to use an FPGA for that, a PIC for this and A Cortex overthere.
Kabelnazs
Fri Apr 20 2012, 08:21PM
Still working on frequency counter:)
Much i have changed to my last mod that have a numeric LCD 4 dig`s the first PCB is complete... t be continued
It will be fine measuring and test tool (ye much work to made but low cost and no need`s to f...k mind with programming stuff :)) ( im a electronics steam punk :) and i don't wanna learn some f..g C++, Assembler or other low Level programming language, to run my projects )
If it was a possibility to program a PIC or Atmel plc`s with me known language such LAD or FDB... but it`s not so simple...
