  • Guests: 43
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
wine bottle CRT/gas discharge tube
haxor5354
Sun Apr 15 2012, 10:56PM Print
Came across this instructables few days ago Link2
too bad I fried all my flyback transformers, my only source of HV is a 10kV 20mA oil ignition transformer, which is AC btw.
would the fridge pump stall if its left on for too long?
the fridge pump seems too weak to pump a proper vacuum because it takes like 50 attemps to get an arc started.
but once its started, it looks AWESOME amazed
here is my own homemade cathode ray tube
1334353546387
1334353593864
1334356337133
1334357514351
1334360060891
1334362120444
Dsc0254dl
Dsc0257n
[Edit: Size]
testtest
Mon Apr 16 2012, 05:55PM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
looks nice. I would strongly suggest a sheet of plexi on top as protection. Local heating could cause the glass to shatter, implode and send shrads all over.
radiotech
Mon Apr 16 2012, 09:49PM
Nice project. Heed safety warnings, at minimum wear face/eye protection.
Can you subject the plasma arc to an AC magnetic field, to see if the beam will
display any wavelike deflection lengthwise or at the end surface? You could try
regulating the beam current, with a Variac on the primary, as a weaker current
will deflect beam further for a given field.
If you do get the deflection to work, and have an audio oscillator and an amplifier,
you could try Lissajous patterns.
Tue Apr 17 2012, 09:07PM
An excellent experiment! smile
If you backfill your glass vessel with cheap helium balloon gas, and then pump it down again, you will find the mean free path of the electrons will be very much longer.
haxor5354
Tue Apr 17 2012, 09:16PM
yea it does get quite hot to touch after a few minutes with the HV on.
how strong of a vacuum can a fridge pump suck?
on the instructables video, theres glowing plasma around the bottle, but mine only have an arc. is it because theres still air inside the bottle?
yesterday i made another gas discharge tube from a thick test tube, can't wait to fill it with helium and see it glow.
2Spoons
Tue Apr 17 2012, 10:03PM
If you want to continue further it would be worth investing in a better vacuum pump. Fridge pumps are OK, but not great. If you want to get down to e-beam levels you are going to need both a good mechanical pump and a diffusion pump (or something similar).
haxor5354
Wed Apr 18 2012, 12:31AM
ok yeah, the author for that instructables used a 2 stage vacuum pump that could suck all the way down to 15 microns. thats >99.99% of a full vacuum!!
i wonder how many microns can a domestic fridge pump can pull
RogerInOhio
Wed Apr 18 2012, 01:51AM
RogerInOhio Registered Member #1034 Joined: Sat Sept 29 2007, 12:50PM
Very good. Another gas that would be cool to back fill it with is argon. It ionizes more easily than air and makes really cool arks.
Wed Apr 18 2012, 05:13AM
Someone should make a fusor using helium, to demonstrate the multipaction effect at accessible levels of vacuum.
-A
Ash Small
Wed Apr 18 2012, 10:43PM
haxor5354 wrote ...
Yes, you are correct.
An arc can only occur in a gas. You could try googling 'Paschen's law' for further information.
As PM has suggested, backfilling with helium (or cheap balloon gas, which isn't pure helium) should give better results at the pressure your pump achieves.
