  • Guests: 30
Pointless endeavor?
ZakWolf
Thu Apr 12 2012, 01:09AM Print
I am quit confident in my transformer making since my last three have turned out quite nice and perform very well.
Link2 Link2 Link2
I was thinking of winding a secondary for a flyback transformer with 40 awg mag wire.
Possible specs(not finished design):
• 40 awg wire
• 24 mm coil per layer
• ~303 turns, without gap…~300 turns per layer
• 2 sheets of 3m overhead projection sheets
• 16.66666666666 layers= 5000 turns
• 17 layers
• Pointless?
My concern comes from something I read on here along time ago, I don't remember what they said exactly, they said something like, "people try to wind forever but at some point there's a limit and it doesn't produce any more electricity".
If so how would I figure out maximum turns for a given transformer?
Turkey9
Thu Apr 12 2012, 03:48AM
My concern would be using 40 awg wire. That is about the same diameter as a human hair. It would be extremely tough to get nice layers and you would probably end up breaking the wire. Or maybe not! It's just my opinion.
ZakWolf
Thu Apr 12 2012, 03:51AM
Turkey9 wrote ...
I thought about that and i wouldn't attempt this but i have found a cheap source. If it doesn't work its OK not that big of a loss, and if it does work it will be awesome :)
m4ge123
Thu Apr 12 2012, 05:11AM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
I would be worried about the 40AWG overheating from too much current, and the self-capacitance of the secondary. I would recommend about 35AWG. It should be fairly easy to wind, and can take a lot more current.
ZakWolf
Thu Apr 12 2012, 05:35AM
is there a limit where the voltage will just plateau??
Thu Apr 12 2012, 06:10AM
As you wind more, the self-resonant frequency of the secondary goes down.
If you drive it above its self-resonant frequency, the output will be reduced, because the coil functions as a low-pass filter.
If you drive it below its resonant frequency, then the output will also be reduced, because the core can support less volts per turn the lower the frequency.
So ideally you would calculate the self-resonant frequency before winding to avoid wasting time and materials. Some old tube-era book might be able to help with that.
ZakWolf
Thu Apr 12 2012, 06:23AM
Steve Conner wrote ...
thank you
Forty
Thu Apr 12 2012, 07:43PM
40awg will probably piss you off to no end when it breaks. I just wound a tesla coil by hand with 36awg and it wasn't too bad, so I'd recommend that if you can get it cheap. solenoids are loaded with thin wire. Two ~1" long x ~0.5" diameter solenoids I had each had over 500ft of 36awg wire on them. Was rather surprised.
Anyways, I think thin, large diameter coils are better for hv flybacks (low turns per layer x many layers.)
There's some fancy self capacitance reason for that, but a much simpler reason to me is to help prevent arc over between the layers at the ends. Less turns per layer means less of a potential difference between the start of one layer and the end of the next. I've made transformers with tons of turns per layer and had this problem quite often, and one arc over with such small wire=ruined.
scotch tape will be your friend when working with transparency strips. I should test the conductivity of the glue sometime to really be sure, but I think you could insulate a transformer entirely with scotch tape if you wanted to. It certainly is convenient.
Unless you glue one layer to the next as you go, I'd recommend being very careful, or stopping at several intervals to pour glue into the sides, so that the windings don't start slipping around and deforming your nicely stacked layers.
You'll also want a core similar in shape to the antique AC flybacks (~square window.)
Be very careful with the end of the wire at the start of the coil (the inner end) because it's a pain when it breaks off and you have to dig out a new piece from the first layer.
I'm probably full of other pointless pointers if you want any.
ZakWolf
Thu Apr 12 2012, 10:49PM
Forty wrote ...
excellent i will give it a try, and if it works i will share.
thanks
ZakWolf
Fri Apr 13 2012, 01:42AM
I found this calculation on a website, it gives an estimated output voltage of a hv secondary.
total number of turns/primary turns= ratio (xxx:x)
secondary ratio* input voltage(ZVS flyback driver) = hv out
3000/8(4 tap primary)=375:1
375*30=11,250 volts
accurate?
