  • Guests: 58
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
tuning a crystal qrp transmitter
alf
Mon Apr 09 2012, 12:01PM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hi,
is it possible to tune the frequency of this? Link2
the variable cap only seems to vary the output power, not the frequency...
im curious as to how one can reply to a cq call when ye cant tune the transmitter xD
thx in adv, Alf.
Mon Apr 09 2012, 01:15PM
You said it's a crystal controlled transmitter. That means the frequency can't be changed, except by buying more crystals.
So, you have to do the CQ calling and hope that others reply on your frequency.
Later you might want to build a VFO for it.
Mon Apr 09 2012, 01:37PM
I think Steve meant that the crystal frequency can only be pulled to a small degree by means of a variable trimmer capacitor in series with the crystal. At 3.5MHz, you may be able to pull the frequency upwards by a few kHz, which can be useful to avoid interference by strong stations. By contrast, adding a parallel capacitor will pull down the frequency by a small amount.
Attempts to pull the crystal frequency by more than a few kHz will usually result in instability.
In solid-state transmitters, crystal pulling is usually achieved by varactors.
alf
Mon Apr 09 2012, 05:48PM
thx for your help, i shall try the parallel capacitor xD
Alf.
