  • Guests: 47
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Minimum altitude on electrolytic caps....
Sat Apr 07 2012, 08:55PM Print
just out of curiosity, whatwould happen if i took a electrolytic cap to 200,000 feet ASL? and what was done for the caps and pressure/heat sensitive PCB components on voyager and pioneer space probes?
Sat Apr 07 2012, 09:59PM
I believe most electronics for satellites are not even sealed from space. I don't know what they do for thermal design, besides using only conduction cooling to the body of the satellite.
For component selection, they use no parts prone to off gassing. No electrolytic caps are used, only ceramic and tantalum caps. (I don't know about film)
Sat Apr 07 2012, 11:13PM
yeah but the orange drop tantalums are electrolytic's too.
Sun Apr 08 2012, 01:10AM
Almost all commercial tantalum capacitors have no liquid electrolyte. They are a solid sintered block.
Steve Maurer
Sun Apr 08 2012, 02:06AM
Steve Maurer Registered Member #133 Joined: Fri Feb 10 2006, 10:27PM
Weston wrote ...
There are a few select non-tantalum electrolytic capacitors that are designed for altitude (80,000 feet), but they are not cheap. They are sealed to prevent outgassing.
- Steve
Sun Apr 08 2012, 02:11AM
ok so solid electrolytes arnt vulnerable to vacuum, but what about heat?
Steve Maurer
Sun Apr 08 2012, 02:33AM
The high altitude non-solid electrolyte capacitors utilize an aluminum case that may be attached to a heat sink. They are usable to +85 C and some even as high as +125 C. Due to the internal vapor pressure at altitude, the capacitors will swell and you need to mechanically account for this in the mechanical design.
Sun Apr 08 2012, 02:57AM
And for the cooling of transistors and IC's? do they have to attach heat pipes to each source of heat when black body wont be enough?
Carbon_Rod
Sun Apr 08 2012, 03:40AM
There is an entire area of engineering that deals with space hardened hardware. However, the orbital trajectory planner and control systems people suggest minimal changes to electronics are necessary. Most satellites have a deflated balloon bladder to detect pressurized atmosphere leaks (usually much less than 1 atm), fans to create artificial convection cooling, and heaters to prevent damaging the semiconductors.
Accordingly, these days even consumer grade electronics in satellites usually survive low orbits around earth as the radiation levels are much lower than in space.
NASA published quite a bit of information about odd failure scenarios most people rarely encounter on earth.
Cheers,
Sun Apr 08 2012, 07:35AM
Ordinary electrolytics must be usable to some extent, since they don't die in Mexico City or the cabin of a passenger aircraft. I think Patrick's question is, what is the extent of that extent. smile
High voltage high altitude design can be challenging. The dielectric strength of the air decreases with altitude.
I believe spacecraft have active cooling for the power electronics. They are mounted to cold plates refrigerated by ammonia or something similar. The heat is dumped to a condenser on the side of the vehicle facing away from the sun.
Spacecraft often have batteries, which are just really big electrolytic capacitors from a construction point of view. Maybe reading about the battery systems could give you some ideas.
