  • Guests: 56
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Wire types
Ben Solon
Thu Apr 05 2012, 04:49PM Print
Hey, does anyone know of a quick easy way to test whether a stranded wire is aluminum or tin plated copper? I tried sandpaper but the wire just got rough and shiny, so it was hart to tell.
Forty
Thu Apr 05 2012, 05:18PM
try soldering with it.
aluminum doesn't solder very well/at all.
Torching a single strand of it might work too, as I don't think I've ever seen aluminum glow.
Compare the weight of it with wire that is known to be copper.
... I could probably list a dozen ways. Just try soldering it, I think that will be a good indication.
Alex M
Thu Apr 05 2012, 05:59PM
Aluminium wire tends to have a more softer feel to it than copper wire does and it will bend easier.
Ben Solon
Thu Apr 05 2012, 06:15PM
It's copper then.
ConKbot of Doom
Sat Apr 07 2012, 03:57AM
experience from helping a buddy rewire an aluminum house says aluminum wires arcing with lots of current on them make nice white sparks, vs blueish/greenish for copper. Got any spare car batteries or ultra caps around?
Sat Apr 07 2012, 04:57AM
Drop it in hydrochloric acid. Aluminum wire will dissolve quickly and produce hydrogen gas. Copper wire should remain relatively unscathed, even if tin plated.
