  • Guests: 57
Gagazet (33)
Chris Cristini (36)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
CRT pinout?
currentkills91
Tue Apr 03 2012, 08:49PM Print
Is there a way to determine the pinout of a CRT tube? I have this little one from an old pocket TV I tore apart, and I wanna use for making a small "oscilloscope" basically. Obviously it wouldn't be really useful, but I found a few schematics online for drivers and things like that, but without knowing the pinout of my CRT it's kinda hopeless. I would just use it to see gate waveforms to see if they look the way they should. I don't have the money right now to even buy a cheap second hand analog scope from eBay so please don't suggest buying one. any help would be appreciated :D
Here's a few pics of the CRT in case they help at all (MOSFET for size comparison)
1333486037 3831 FT0 Dscn4561
1333486121 3831 FT0 Dscn4565
1333486121 3831 FT0 Dscn4564
Tue Apr 03 2012, 09:30PM
TLY80602A is the part number of a Panasonic yoke.
The tube's own part number may be printed on the glass under the yoke.
Do you know if the TV was colour or black and white?
If it was monochrome, then it probably came from the Panasonic TR-1000 series, (1980 - 1984) and if colour, from the CT-101, which was produced only in 1984.
If the tube type number is not printed on the glass under the yoke, then identifying the TV model number will be the key to identifying the tube, and hence the pin-out.
currentkills91
Wed Apr 04 2012, 01:20AM
Okay, I should be able to remove the yoke assembly rather easily? It came from the TR-1020P which was black and white.
I will remove the yoke, and see if there is a number. I should've guessed there might be a number under that x.x
Wed Apr 04 2012, 06:52AM
I wouldn't remove the yoke without first making marks with a CD marker on the tube ABOVE THE YOKE so they don't rub off!! this will help realignment later.
I also have a "flat" CRT here if its any use, tried to turn it into a 'scope tube but you need the plates inside the glass not painted on the outside unfortunately.
Also there are PIC based 'scopes, 12F675 and outputs B/W video.
Not very high bandwidth but there are ways around this, such as the heterodyne + lowpass filter method.
For even higher frequencies use a TV tuner, frequency counter and 20 turn trimpot on the tuning diode.
-A
Wed Apr 04 2012, 07:07AM
This is a magnetic deflection CRT, fun to play with but pretty much useless for making an accurate scope. You certainly won't be able to view gate waveforms.
The simplest driver circuit is the TV that it came out of. tongue
currentkills91
Wed Apr 04 2012, 11:51AM
I did a fair bit of google searching and found a lot of examples of decent "scopes" made from CRT's like mine. They dont have any grid or anything fancy, but are claimed to work into the MHz range. I just need something to see if the signal is square, triangular or sinusoidal. It doesn't have to be perfect, just something I can use to test the drive signals to see if they are usable.
I managed to easily get the yoke off, very simple, but going in I didn't know that. lol I didn't find any numbers or letters though :( So My guess is, is the part number was on that little sticker maybe? If so I have no idea how to find the pinout...
Wed Apr 04 2012, 12:04PM
There are plenty of small CRTs that look like yours but actually have electrostatic deflection. (you can tell by the absence of yoke coils)
Yours is magnetic deflection and certainly won't work into the MHz range or display waveforms properly, unless you built a very specialised amplifier for it. (and you'd need a scope to troubleshoot the amplifier smile )
Wed Apr 04 2012, 01:13PM
It seems likely that your CRT is a Panasonic 40HB4, which survived the pocket TV era, and had a new lease of life as a viewfinder in video cameras.
Unfortunately, none of the usual datasheet sources - Datasheet Archive and Frank's Electron Tube Data, two of my favourites - have a sheet for it that I can find.
Failing a datasheet, you can often work out the pin connections by careful study of the interconnections you can see through the glass (where this is possible). The simplest pair of pins to identify are the heaters, which will be the only two pins that have a low resistance between them - in an undamaged tube. (Of course, you'll not be able to find them with an ohm meter if the heater has failed open-circuit, as does happen with thermionic valve failures.)
currentkills91
Wed Apr 04 2012, 02:04PM
Well the TV worked just fine, I just didn't like how sensitive it was. (with tuning) I have been rather gentle with it since I took it out, so it shouldn't be damaged. Although I have noticed, and it's visible in the first pic, there is a piece of white stuff broken away from the rest of the gobs of it. Does that white stuff do anything important? If anybdy even knows what I'm talking about.
And hmmm, well I suppose it would be cool just to build something to be able to view waveforms. If it doesn't work good enough to view waveforms I'll just use it for a "spectrum analyzer"? for my stereo, it would be kinda neat.
So the goal is, use google and my eyes to try to figure out the pinout, and then build a driver circuit for it(:
Thanks for all the help guys!!
Wed Apr 04 2012, 11:09PM
currentkills91 wrote ...
Have you done that yet? Put the CRT back in TV system and get a raster. Disconnect the horizontal deflection - now you have a vertical line as the spot scans top to bottom. Now drive the horizontal deflection as if it were a speaker. If you want a horizontal baseline, you can rotate the yoke (or the TV) 90 degrees. Or connect vertical drive to horizontal coil. Link2
