  • Guests: 38
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Jet Engine Project
Neil
Sun Apr 01 2012, 10:50AM Print
Neil Registered Member #1458 Joined: Wed Apr 30 2008, 09:47AM
After building Tesla Coils and HV Capacitor Banks I decided to start working on a slightly different project, a Jet Engine. I thought some of you may be interested in this despite the lack of electrical content in it, so am posting my progress so far in the General Science section.
I decided to base the design on using a Turbocharger rather than building those more critical parts myself, they are easy to acquire, reasonably cheap through their mass production and are designed to run at the RPM I am after. The Turbo I purchased was the largest I could find online, rated for a 1000HP engine.
Below are details of my progress so far.
First off I drew it up in Autocad 2011 as a 3D model to get all my sizing right, then drew construction drawings from this to allow me to order my steel and stainless steel
1333271374 1458 FT0 With Fuel Tanks
I purchased 316 stainless steel from a company that would plasma cut it with a computer controlled machine from submitted drawings, they came out very neat. Other assorted parts are in the picture too.
1333270617 1458 FT0 New Parts
This picture shows the 90 PSI fuel pump & regulator, 80 PSI oil pump, ignition system and oil cooler for the turbo
1333270950 1458 FT0 Dsc 0001
I then started pressing up the stainless steel to shape
1333271599 1458 FT0 Pressing Plates
1333271599 1458 FT0 Combustion Chamber Bend
All the flanges were then drilled, and I could tack it all together
1333271702 1458 FT0 Plates Drilled  Tapped
1333271702 1458 FT0 Progress For The Weekend
I then started working on the combustion chamber, the jet is designed to run off a liquid fuel such as petrol rather than a gas. I have made a flame tube to help hold the flame and ensure the inrushing air doesn't blow out the flame, then to allow the fuel to vaporise I have made an evaporator tube which extends up into the flame to heat the fuel before doubling back and allowing the vapour to exit at the end. This will hopefully avoid large burning droplets of fuel making it to the turbo, and improve efficiency.
1333272156 1458 FT0 Dsc 0116
1333272156 1458 FT0 Dsc 0122
1333272156 1458 FT0 Dsc 0142
1333272156 1458 FT0 Dsc 0149
At the other end, I have welded some pipes around the circumference to give the flame tube something to rest on and centre it, and also to provide some restriction to the airflow. Ideally most air will enter the flame tube through all the small holes, however some air will flow on the outside and through the pipes welded around the circumference, this serves 2 purposes, it will keep the combustion chamber cool so radiant heat doesn't burn hoses and any other items in the frame, and also provides a cool surrounding to the hot gas to allow it to travel up to the turbo hopefully keeping the transition and bend cool also.
1333272445 1458 FT0 Dsc 0130
The Jet will also have an afterburner which is the purpose of the nozzle. I have also welded a flame holder in this to try and maintain a flame and not let it be blown out. The flame holder extends back up close to the entrance of the exhaust gasses from the Turbo, the flame will them extend over the pipes leading to this and help to vaporise the fuel to allow as much fuel to burn in the nozzle as possible before exiting.
1333272789 1458 FT0 Dsc 0176
1333272789 1458 FT0 Dsc 0179
1333272789 1458 FT0 Dsc 0181
1333272789 1458 FT0 Dsc 0184
The Jet is starting to take shape as the Turbo and piping is assembled
1333272907 1458 FT0 Dsc 0158
1333272907 1458 FT0 Dsc 0165
1333272907 1458 FT0 Dsc 0168
The fuel will be ignited using 2 x Jacobs Ladder kits purchased from Jaycar, they are connected to spark plugs, one box will be connected to the combustion chamber, the other will be connected to the afterburner . The circuits have been mounted into a box to keep it neat and protected from damage.
1333273262 1458 FT0 Dsc 0019
1333273262 1458 FT0 Dsc 0021
The control box is made from lexan and wood. I still have to finish it by painting the front panel, install the switches onto that panel and connect it all to the Jet. It has 6 gauges to monitor the Jet:
Pyrometer
Oil Temp
Oil Pressure
Fuel Pressure
Boost Pressure
Voltage
1333274610 1458 FT0 Dsc 0026
1333274610 1458 FT0 Dsc 0027
1333274610 1458 FT0 Dsc 0029
1333274610 1458 FT0 Dsc 0028
Fuel and oil will all be run in stainless steel braided hose with Aeroflow fittings.
I still have a fair bit of work to go to finish, I will post an update as more work is completed and then a video when its finished and running.
Ash Small
Sun Apr 01 2012, 11:30AM
Very nice work, Neil. Keep us posted on progress.
Sun Apr 01 2012, 06:45PM
Nice work. What are you going to do with it?
Neil
Mon Apr 02 2012, 10:26AM
At this stage the plan is just to get it running and enjoy using it. If it produces any useful thrust, I may consider extending the frame, adding wheels, steering, a seat etc but will look at that later on, the thought of the noise and flame is what is driving me to finish it as I think it will be quite interesting to see running.
Mon Apr 02 2012, 02:04PM
Have you done anything like this before (engines, welding, brazing). It looks nice. Make sure you take videos.
Mon Apr 02 2012, 02:58PM
Yes, this looks like a great project! I'll be very interested to see it done. What thickness of metal did you use? Some of the parts look seriously hefty.
Neil
Tue Apr 03 2012, 07:22AM
Thanks for the comments.
Yes I was once what they call a boilermaker here in Australia, not sure what they call it in the rest of the world but its basically a trade on welding and fabricating metal so I have had a lot of past experience in that regard.
Steve, most of the plates and pipes are 6mm. It is quite heavy and hard to bend/shape/drill, however I thought it was worth it as I wanted to ensure it was thick enough that it can cope with heat well without glowing instantly, it might allow me to run the afterburner for more time before the end wants to glow red. I will be the first to admit I have probably overdesigned the thing, but given the time and money this is costing me to make, I thought I would aim more for reliability.
Chip Fixes
Tue Apr 03 2012, 09:33PM
Wow! Looks great! I'm excited to see the finished product, on another note.. Lexan is fantastic stuff!! Virtually unbreakable
Neil
Wed May 16 2012, 08:12AM
I have now finished my Jet. I am very pleased with the result. So far I have only commissioned it, running it at idle to iron out the bugs, one of which caused the turbo to be damaged due to low oil pressure, however I have sorted that issue out now, just waiting for the replacement turbo to arrive.
Even at idle it pumps out a huge volume of gas, I am really looking forward to increasing the RPM and seeing how much thrust I get. I also need to tune it a bit to get the afterburner to run constantly when I turn it on.
Here is the YouTube video, it goes through most of the build pictures at the beginning and the starting of the jet and running it during the commissioning is toward the end
Some pictures of the final build of the jet are below
1337155413 1458 FT136432 Dsc 0007
1337155413 1458 FT136432 Dsc 0011
1337155413 1458 FT136432 Dsc 0015
1337155413 1458 FT136432 Dsc 0013
Jrz126
Wed May 16 2012, 03:24PM
Looks good.
Is it safe to stand that close to it? I'd at least wear long pants and a welding jacket.
I was cutting into a car and had a gas shock inside the bumper blow up in my face. Spent a month on the couch recovering. I'm a bit more cautious around fire now.
