  • Guests: 24
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
How do I tell the difference , visually, between a blue cap and a MOV
JamesH
Sat Mar 31 2012, 11:11AM Print
JamesH Registered Member #579 Joined: Mon Mar 12 2007, 09:45AM
I try and salvage components for my projects but am never sure how to tell the difference between Blue Capacitors and MOV |( self healing fuses)
The coding does not seem to help
I have a Capacitance meter
1333192283 579 FT0 Cap Mov 002 Medium
1333192284 579 FT0 Cap Mov 003 Medium
1333192284 579 FT0 Cap Mov 004 Medium
Sat Mar 31 2012, 11:46AM
Hi James,
S20K300 = VARISTOR 300VRMS 20MM RADIAL made by Epcos.
Its datasheet is here: Link2
14V511K is a metal oxide varistor made by several manufacturers. Look for part
number TND14V-511KB00AAA0 (previous part number TNR14V511K) here:
JamesH
Sun Apr 01 2012, 09:33AM
Thanks for the quick reply
I think the rest are just caps with complex information
I would also like some one to explain what the term X2 means on caps as I have often seen it quoted but do not understand its meaning
the other items :
JNC JY472M 400 X1 250
250Y 71M
JNC JY103M ( ? 10nF cap? )
400~ X1 250
250~ y263H
__________________
xx332mmx1 y1
mj502
250~ (?25 Ac?)
JNCJY472M
400~ x1250
250~y271H
Sun Apr 01 2012, 10:38AM
Capacitors made to standards X and Y are capacitors certified for safe use in mains line filters - capacitors to reduce interference getting into, or out of, domestic appliances, for example. Such capacitors may be connected across Live and Neutral, and/or between Live and Earth, and therefore have to be able to withstand not only the peak mains voltage, but also high voltage spikes which appear on the mains for a variety of reasons, lightning strikes, switching transients, and so on.
Basically, capacitors of Class X are suitable for use where capacitor failure is not likely to result in electric shock to the user/consumer. Class Y must be used where failure would pose a risk of shock to the user/consumer of an appliance if its Earth connection is lost. Class X1 capacitors are designed to withstand 4 kV spikes, and Class X2, 2.5 kV spikes
There are now seven of these classes defined in European standards literature, which is revised so often it is hard to keep track of it all, but you'll find a good explanation in readable English here: Link2
There is a nifty capacitor code calculator in a piece of free software called Electronics Assistant, which you can download here: Link2
