  • Guests: 31
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Resistor resistance decreases as the temperature is increased?
Alex M
Mon Mar 26 2012, 07:54AM Print
I made a rather strange observation whilst tinkering with my home-made infra-red LED array circuit the other day.
Whilst modding it to work with a 12v battery I noticed that the resistance of one of the resistors actually dropped when heat from a soldering iron was applied to the leads. I have always though the opposite should happen (which it did for the other resistor on the adjacent array of LEDs).
Anyone have any explanation as to why it did this? I am not sure what types of resistors they were as they were ones salvaged out of old electronic boards.
Here is a video demonstrating Link2
Any explanations would be great,
Thanks.
Daedronus
Mon Mar 26 2012, 09:24AM
Not all components/materials have a positive temperature coefficient, some have it negative.
Bjørn
Mon Mar 26 2012, 10:38AM
If you remember back to the first light bulbs with carbon filament they needed series resistors to avoid thermal runaway because of their negative temperature coefficient. That is probably a hint about what your resistor is made out of.
A very simplified way of thinking about it is this, if the material have low electron mobility and high specific resistance, higher temperature will knock the electrons around and make them more mobile. In a low resistance material increased temperature will have the opposite effect and slightly disrupt the already easy flow.
Inducktion
Mon Mar 26 2012, 06:36PM
Idle thought; If that is so Bjorn, wouldn't we be able to heat up wires enough to cause them to have 0 resistance at some temperature?
Dr. Slack
Mon Mar 26 2012, 06:49PM
Inducktion wrote ...
Only if you fit a straight line to a few points in a limited range, then extrapolate way beyond where it's a good fit
Mon Mar 26 2012, 08:04PM
Yeah, and no decent scientist does that, they leave it to economists.
If I remember Semiconductor Physics 101 right, negative temperature coefficient of resistance is caused by electrons being bumped up into the conduction band by thermal agitation. This can free a lot of electrons. A related phenomenon is electrical breakdown in gases.
But no matter how many electrons are in the conduction band (a metal has all of them there) they are still subject to thermal jostling by other electrons and collisions with other atoms as they move. This is what causes electrical resistance.
To get zero resistance, you have to start with a metal (lots of free electrons) and then cool it to a very low temperature. As the thermal agitation decreases, interesting quantum effects appear, allowing the conduction electrons to move without bashing into anything. The result is a superconductor, which does indeed have literally zero resistance.
radiotech
Tue Mar 27 2012, 04:10AM
Do another test. Switch the multimeter to DC volts, clip it on to the resistor, then heat the resistors
to see if some thermo-electric effect exists. If it does, that is changing the resistance as read by
the meter, because of the phantom current.
It is common with metalic resistors where the lead wires are different than the resistance element
metal.
