  • Guests: 46
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Help with this part?!
currentkills91
Mon Mar 19 2012, 08:44PM Print
I tore apart an old monitor and found this part 2S0765 I checked the datasheet and I couldnt find any application circuits. Could somebody help me figure out how to use this part for a power supply. I wanna use it for the various voltages needed for my mini tesla coil I was working on a while ago. The power supply problem is basically what prevented that from being operational. I'd really like to figure out how to use this chip. Any help is appreciated :D
EDIT: Would this circuit be similar? - Here
Wolfram
Tue Mar 20 2012, 08:27AM
That circuit you linked to will be similar, but flyback converter design is NOT easy. I found this Link2 document with a good introduction, and for some more comprehensive information I can recommend "Switching Power Supply Design" by A. Pressman. As you can see, flyback converter design is not easy, and your best chance of getting anything working is rewinding the original transformer that it was used to drive in the monitor. It's not guaranteed to work but at least there's some hope of getting it working.
currentkills91
Tue Mar 20 2012, 09:48PM
Yeah I know it's not easy, I've tried before but not with a chip like this. I'll read up on the subject, but can you or somebody else explain how it would work? Like the chip itself
