  • Guests: 76
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Contactors
Mon Mar 12 2012, 06:04PM Print
if i buy some contactors, (these ones) is there a chance they could be fake like some MOSFETS and dont handle the full current?
Thank,
Tom Williamson
Mon Mar 12 2012, 06:39PM
Very little chance at all, Tom. I'd be confident in buying that, and using it for the purpose and ratings for which it was designed.
Mon Mar 12 2012, 07:07PM
ok, thanks ^^, also is there anywhere good to buy cheap 40A single core wire for wiring such objects?
-tom
Shrad
Mon Mar 12 2012, 07:40PM
big workplaces like naval workshops, bus workshops, and truck workshops might be a place to buy end-of-rolls of battery cable which can handle a permanent 24V to 48V 150amps
Harry
Mon Mar 12 2012, 07:47PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
This would do it if you live near a wickes: Link2
If you run the three wires in parallel that is.
Mon Mar 12 2012, 07:58PM
im looking to do this in a professional style, everything ducted and clean
Mon Mar 12 2012, 08:30PM
In the UK, 6mm T&E (twin and earth) is the standard for 40A electric cooker circuits. There are UK sellers of this on ebay.
Mon Mar 12 2012, 09:37PM
ah, ok, thanks
Nicko
Tue Mar 13 2012, 04:26AM
Tom Williamson wrote ...
They are most probably fine, however note that contactor contact ratings are typically for AC current and that their DC ratings are usually considerably lower. Also, you may need to use a snubber to prevent the contacts sticking even with AC if you have an inductive load (just like you'd snub a normal switch).
If the contactor has multiple poles, you can up the allowable current by wiring poles in parallel and up the allowable voltage by wiring poles in series (increases air gap) - I did these mods in my can-crusher which used contactors like yours - I used the NO/NC extra poles to implement a lockout to prevent accidental firing & to discharge the caps etc. when power was removed (or lost), i.e. fail-safe...
See: Link2
radiotech
Tue Mar 13 2012, 05:53AM
The other thing about some contactors is they may have kits of replacement contacts.
