  • Guests: 51
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
High Side Low Side driver ratings
Turkey9
Mon Mar 12 2012, 05:29AM Print
Hello,
I was looking at a mosfet driver from TI, the UCC27211, and have a question about one of the ratings. It says that the maximum Boot Voltage is 120V. What exactly is the boot voltage? If it is the maximum that the positive rail can be in the circuit you're switching, it seems a little pointless. If the device was designed to work in circuits that ran off of rectified mains, such as most SMPS, the maximum voltage would have to be closer to 200V at least! Can someone explain this rating and function of the boot voltage? Thanks!
Avalanche
Mon Mar 12 2012, 09:11AM
It looks like it's the total highest voltage allowed on the 'HB' pin, which is the top of the bootstrap capacitor. So up to 20 volts of that will be the bootstrap voltage, and the rest will be the high voltage DC rail (so the maximum you can have on your DC rail is the 'boot' voltage minus your gate drive voltage).
So not much good for off-line power supplies, but it would be good enough for some battery powered stuff (eg. power inverters that run from 48 to 72VDC)
