  • Guests: 35
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
How to protect Oscilloscope inputs from overvoltages?
ifryd
Tue Mar 06 2012, 10:47PM Print
ifryd Registered Member #4215 Joined: Wed Nov 16 2011, 09:45PM
As in subject... Do you use any protection circuits together with oscilloscope? I don`t want to blew my oscilloscope...
I bet I saw here such circuits here but I cannot find them now.
Mattski
Wed Mar 07 2012, 03:44AM
You could get some TVS diodes: Link2 they come in single diodes which protect against positive OR negative spikes, or back-to-back (anti-series?) packages which will protect against both positive AND negative spikes.
Or regular zener diodes, or MOV's: Link2
Wed Mar 07 2012, 05:42AM
Use suitably rated 'scope probes and your intelligence.
ALWAYS ensure the 'scope is "earthed" via the power cable for YOUR protection.
(if the 'scope is mains powered)
If the circuit that you are going to probe has voltages greater than a few hundred volts present then use a high voltage probe.
My 'scope probes are almost always set to x10
this is mainly to minimise the load on the circuit under test
it also gives some protection for the 'scope inputs.
Over 40 years of 'scoping I've replaced probes many times due to mechanical failures
I've never blown a 'scope input.
Read and understand the 'scope probe specifications.
I have never added protection for the 'scope inputs as it would mess-up the frequency response ..e.g. capacitance of tvs/zener.
ifryd
Thu Mar 08 2012, 12:11PM
Thank you guys I see now scope probes are very important. They have internal protection...
radiotech
Thu Mar 08 2012, 08:13PM
They do not. The probe will pass enough current to melt their cables if you use them unsafely.
For the type of applications with TCs and SMPS , the key factor is the voltage vs frequency
de-rating curves, mentioned previously as "understanding the specs".
1331237597 2463 FT135504 P6106
Pinky's Brain
Thu Mar 08 2012, 08:45PM
The only way I see to protect a scope is with a sacrificial buffer amplifier, you can put TVS on the output of that.
Thu Mar 15 2012, 06:48PM
yeah the TVS'es have appalling capacitence if not buffered, i was told by others here on the forum to use spark gap surge asrestors which are very fast and neglagable capacitience, i was going to use 90v breakdown ones on the tip of the probe, before the times 10 division circuit.
Thu Mar 15 2012, 06:59PM
when i first used my Oscilliscope probe, i failed using it and melted the entire thing :o
teravolt
Fri Mar 16 2012, 04:25AM
I'm with Sulaiman know what you expect to mesure I bought a 100:1 probe with a 2500 volt rating. If you don't know you could make a basic resistive probe to get a idea of what you may be dealing with. You could invest in a isollation transformer. any 120, 240vac to 120, 240vac transformer will do for basic use. it does not have to be labratory grade. Just find a surplus place or ebay. the bigger the better. If you ground a probe make shure that the place you are grounding it to is connected to the same safty ground as your scope.
