  • Guests: 45
3KW flyback transformer CCPS{**link**}
Mr.Black
Fri Mar 02 2012, 09:09AM Print
Mr.Black Registered Member #3960 Joined: Mon Jun 20 2011, 06:27AM
Hello every one!:-D
This is my new work
I use two Flyback transformer output 3KW arc
1:This is my Regulator a digital ammeter and an old-fashioned ammeter
139 4513 D5ddf3a784fe833
2: transformer
139 14505 3ad1764d18e4bfe
3:Fullbridge board(use four G40N60A4 s)
139 14505 4aed7e3eff2896e
4:and a system schematic
Arc
139 14505 C32514448b8c6d7
139 14505 68642a115974094
Arc Length about 40cm~~~
Watch the video click here
http://v.youku.com/v_show/id_XMzUzNjExMzA4.html
17.0A in Bus139 14505 Abd044f7b729de7
1330680093 3960 FT135272 Qq20120302164605
Arc1
1330680253 3960 FT135272 Qq20120218001432
Arc2
1330680450 3960 FT135272 Qq20120218001442
Dr. ISOTOP
Fri Mar 02 2012, 10:15AM
Non-resonant switching? I'm amazed your transistors are still alive :P
Mr.Black
Fri Mar 02 2012, 02:23PM
Yes...this system work so well.
Spend 1min G40N60A4 only 51°C~
And i think it can work in higher Bus voltage
because you can see perfect Square wave in oscilloscope
teravolt
Sat Mar 03 2012, 03:21AM
what kind of transformer did you use, good work!
Mr.Black
Sat Mar 03 2012, 08:02AM
Thank for your compliment:-D
and it is gate voltage
1330761723 3960 FT135272 Qq20120212030206
Sat Mar 03 2012, 07:40PM
how can you be sure your reallly putting out 3kW, flybacks due to thier air gap, the magnetic circuit is not easy to approximate.
If you cant measure the V and I simultaneously, im always skeptical as to output power claims based on merely heat rise after a short interval run time.
its still cool though, Its nice to see another having success without a ZVS/ZCS design.
Mr.Black
Mon Mar 05 2012, 02:21PM
Yes, I agree with you
I call it "3KW ARC"is because the whole system is very cool
But now I believe it is called the input 3KW better
Mr.Black
Mon Mar 05 2012, 02:28PM
After a few days i try to 180V bus voltage
arc1:arc2
1330957700 3960 FT135272
1330957700 3960 FT135272 3
Marko
Mon Mar 05 2012, 04:10PM
Hi sir, nice work - can you show us what transformer are you actually using? It's hard to tell from your pictures.
IGBT's are pretty tough bastards as long as they are not let to overheat. I've ran a fullbridge of 30N60's up to about 25kVA with hard switching, for a while at 100kHz and they lived.
I think it was Steve Ward who initially spread the rumor of how horrible hard switching is compared to SLR topology. While it certainly is a benefit for capacitor charging, I'm not sure what it does when load are arcs - resonant frequency changes depending on arc length!
On the other hand, I think Steve mounted his igbt's with a single screw and sil pads. That might be the reason why they initially blew up.
Marko
Mr.Black
Wed Mar 07 2012, 03:42PM
I made two flyback transformer back to back, sharing a primary coil in parallel secondary coil
Model is"菲利普代用包"
This model can not be translated into English....
On the other hand, can i take a look at your 25KVA arc?I think it is a very strong
1331134953 3960 FT135272 Qq20120307233635
