  • Guests: 27
Singing ZVS driver
Experimentonomen
Tue Feb 28 2012, 01:31PM Print
I normally rarely to never touch high voltage stuff but since i dident have anything to do for the past few days because my computer broke down, i decided to build a little ZVS driver and have a go at audio modulating it.
Heres how it turned out: Link2
The power supply is 18VDC 160VA(two 80VA transformers in parallal) and a smoothing capacitance in the order of half a farad.
For the audio modulation i put a transformer in series with the power supply.
Platinum
Tue Feb 28 2012, 02:52PM
Hmm I would like to do this, but my ZVS is acting up, it has very good output then drops to nothing, maybe core saturate...
Do you have a schematic of how you implemented audio modulation, as this is pretty awesome well done!
Experimentonomen
Tue Feb 28 2012, 03:48PM
There is really only one way to do it and i already described it. :P
Tue Feb 28 2012, 04:20PM
You can PWM the series inductor with a high-side switch, but a clamp diode from gnd is needed. I think the inductor can be put to the negative of the driver with a little modification, then you can PWM it with a low side switch.
TwirlyWhirly555
Tue Feb 28 2012, 04:49PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
I tryed a audio modulated ZVS to , i imposed the audio on the gates of the mosfets via a capacitor connected to the gate then to a audio signal , supply was 40 volts and there was 12 volts on the gate drive ,
Arcs where similar to a normal ZVS , and it played music very very quite but the quallity was no bad :D
Tetris
Tue Feb 28 2012, 05:10PM
What are the specs and circuit?
Experimentonomen
Tue Feb 28 2012, 06:26PM
Like i said in the first post, the average mazzilli zvs driver, with two inductors instead of the centertapped primary winding.
Platinum
Tue Feb 28 2012, 07:24PM
Sorry I am confused, two inductors, and PWM a inductor?
Can I just audio in there? I do not have any PWM IC's..
Experimentonomen
Tue Feb 28 2012, 07:33PM
Theres no pwm what so ever involved. U can clearly see the big 300VA toroid used to inject the audio signal onto the DC power input to the circuit.
Tue Feb 28 2012, 07:44PM
I just commented on Experimentonomen's statement that there's just one way to do it... There is at least one more way and that's the PWM I mentioned, and it's lossless. You just need to use the single inductor circuit.
