  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Flexible (coiled?) Multi Conductor Cable Sources?
Mon Feb 27 2012, 07:52PM Print
I'm trying to locate some cable, preferably coiled like older style headphones or telephone cords, that will tolerate extensive flexing (being used on an aviation headset) and has 8 conductors or more.
Really, some highly flexible, coiled Cat5 would be perfect, but I can't find anything of the sort. It doesn't need to tolerate high voltage or current, so long as it can be fairly easily soldered, I'll be happy.
Anybody have any recommendations for sources or search terms to use, or possibly common uses for something along these lines?
Mon Feb 27 2012, 08:08PM
"Coiled Lead" Link2 Link2
"keyboard cable" Link2
Mon Feb 27 2012, 08:21PM
Sulaiman, the keyboard cable is a great idea. My only concern is just how light the individual wires are. The couple keyboard cables I've cut up before were awfully thin, and weren't material that was easily soldered. It would seem this cable is copper at least, so its worth investigating.
Just before you posted that, I thought of DB-9 serial port extension cables. I've found several that should be flexible enough, but I haven't found a coiled version just yet.
