  • Guests: 30
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
igbt halfbridge
ben5017
Mon Feb 27 2012, 06:37PM Print
ben5017 Registered Member #3315 Joined: Thu Oct 14 2010, 04:23PM
can someone explain what exactly an igbt halfbridge is? what are the advantages and disadvantages of other igbt switching methods. what makes it so good for use in a coilgun? thanks in advance, i am having trouble understanding it from online research alone
Forty
Mon Feb 27 2012, 07:41PM
Well for coilgun use, using two igbts allows you to first switch the capacitor current into the coil, and then switch the coil energy back into the capacitor bank. It improves overall efficiency because you can regain some of the energy rather than dissipating it as heat.
edit: Here's a recent thread about such a coilgun Link2
ben5017
Mon Feb 27 2012, 07:56PM
forty: thanks, I have been keeping an eye on the thread for awhile. i am working on one similar and have just finished my charging and optical trigger setup. Im just trying to wrap my head around the half bridge switchin setup
ben5017
Mon Feb 27 2012, 11:16PM
if my igbt need to withstand approx 1000 amps for a few ms do you guys think i need to get a igbt brick? if i want an igbt halfbridge configuration i need 2 per stage correct?
