  • Guests: 68
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Restoring a sealed 12v 7ah rechargeable battery?
Platinum
Mon Feb 27 2012, 03:01PM Print
I have one of these, I found it, I've opened the cap and there is 6 holes for whatever you put in here, water?/sulfuric acid? so i think there are 6 cells, how can I restore it, and recharge it?
Thanks....
Mon Feb 27 2012, 06:01PM
I've never managed to restore one. Never tried squirting water in the holes, but I doubt it would help. On the bright side, they're pretty cheap if you want to just buy a new one.
Letting these batteries sit around flat is what kills them. If you do buy one, keep it charged and it'll last for years.
Platinum
Mon Feb 27 2012, 06:17PM
Do these batteries take normal 35% sulfuric acid?
I'll charge it with 13v...so if it holds anything...
Mon Feb 27 2012, 08:23PM
Don't know what they take, but I do know you're not supposed to add acid to a battery. Only the water is lost in use.
Alex M
Mon Feb 27 2012, 08:46PM
See Link2
Also they should be bulk charged at 14.15v.
Mon Feb 27 2012, 10:01PM
Looks like the typical bilge I'd expect on Instructables. I notice he never posted any measurements of capacity before and after, probably because it was 0 in both cases.
Platinum
Mon Feb 27 2012, 11:02PM
Well I have some good battery acid, I'll put some in, and charge it, at 13v 1a?
See if anything happens.
Wolfram
Tue Feb 28 2012, 12:52AM
Platinum wrote ...
Did you not read Steve's post?
Alex M
Tue Feb 28 2012, 04:11AM
Steve Conner wrote ...
From the look of the comments it seems to work.
Not everything on instructables is total rubbish, there are some good how-to's on there cheesey
Tue Feb 28 2012, 07:31AM
From the look of comments elsewhere on the Internet, putting special rocks on your hi-fi makes it sound better. Just sayin! tongue
If you do try it, please measure the capacity before and after. Maybe time how long it can run a 12v lamp. Nothing like hard data.
I wouldn't expect it to work, because lead acid batteries die by the active ingredient, lead oxide, turning into useless lead sulphate. Or by the electrodes simply falling apart. Neither water nor acid will reverse those processes.
