  • Guests: 34
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
VTTC oscillator...
Inducktion
Mon Feb 27 2012, 02:25AM Print
Yep! What should I change in it before I go testing it out? The feedback wire is going to be changed to a CT transformer, so that's good, and the potentiometer adjusts the gain allowing for a decent degree of control. (at least on the schematic anyway!) It would be used with a 811A, by the way! I also need to add the secondary side capacitor, but the sim doesn't really allow that to work...
Mon Feb 27 2012, 02:10PM
It's not easy to understand what this circuit is all about in terms of the 811A datasheet
For example, why is there a fixed (though variable by VR) positive bias on the grid, when we would expect to see bias values down to as far as -200V in Class 'C' Oscillator applications?
teravolt
Mon Feb 27 2012, 05:02PM
so do you want to do grid modulation
