  • Guests: 24
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Vacuum pulling/sealing
ZakWolf
Sun Feb 26 2012, 10:44AM Print
Couple quick questions, i have zero experience with this.
I want to pull a vacuum on a project box full of oil to remove the air between transformer layers.
What pressures am i looking at?
Do i need to seal it after the vacuum is pulled? If so do i need a self sealing valve?
Thanks
hboy007
Sun Feb 26 2012, 11:49AM
as you said, the vacuum is there to remove air entrapment. Once the blubbling stops, you can vent the box. Just make sure the windings are not drained by rotating the whole thing.
Usually, any roughing pump that reaches 10^0 mbar will do.
Water jet pumps however (as they reach 15-20mbar depending on the medium temperature) will lead to doubtable results.
ZakWolf
Sun Feb 26 2012, 11:54AM
hboy007 wrote ...
thank you, how about a hand held automotive pump?
should i drill a hole and insert a nipple or somthing to connect to the vacuum. and after just plug it ?
hboy007
Sun Feb 26 2012, 12:00PM
any leakage will make the hand held pump unusable.
Can you install a foil collar around the transformer? Depending on the size of your box, you could fill it up completely with oil, then pump out the dead volume and let the displacement work for you.
ZakWolf
Sun Feb 26 2012, 12:24PM
hboy007 wrote ...
Can you elaborate a little more please
Ash Small
Sun Feb 26 2012, 01:53PM
The object is basically to pump out the air. Keep pumping until all bubbling has stopped, then, when you release the vacuum, the oil level drops as the oil fills all the voids where the bubbles were.
You will be surprised by how much the level drops, so ensure you have a good 'head'.
Shrad
Sun Feb 26 2012, 09:11PM
you can also vibrate the whole bath, it boosts effectiveness
ZakWolf
Sun Feb 26 2012, 10:47PM
Thanks every one
Its gonna be enclosed so i wont be able to the bubbles. Should i just run it for a long time?
Or should i do it in a clear container and move it afterwards
Sun Feb 26 2012, 11:31PM
You can do a better job by evacuating the box dry, holding it that way for a while,
then letting it suck in previously dried and degassed oil.
Like the pros do. Link2
Of course that needs more equiment, time, and trouble. Maybe not necessary if voltage stresses are modest and the project doesn't need to work for decades.
1) to better extract moisture from inter-layer insulation, magnet wire insulation area, etc. which starts in equilibrium with the room air humidity, and would otherwise contaminate the oil.
2) When pumping on an oil-filled pot, the pressure at the bottom can be no less than the hydrostatic pressure of the oil.
Say, 9 mbar (7 torr) under 100 mm of oil, for a bubble radial expansion factor of 5.
Why waste your pump capacity? A 2-stage mechanical pump should get you to 1 mbar (10x expansion) in seconds. If you're patient, maybe down below 50 microns (1/16 mbar; 25x expansion -- if there were bubbles).
