  • Guests: 42
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
What does a $1,600,000,000 corporation do when it can't figure out how to lower RDSon?
Adam Munich
Sun Feb 26 2012, 03:44AM Print
Double up on what they've already got, so it seems Link2
Turkey9
Sun Feb 26 2012, 04:47AM
Ha. I like it. I imagine lowering RDSon is a pretty hard task, similar to getting down to 32nm transistors. Putting two switches in parallel seems the clever and cost effective thing to do. I have seem a common MOSFET that can handle almost 700A pulsed, either.
Sun Feb 26 2012, 09:13AM
That's a whole lot of MOSFET! :O I'll check them out for an experiment I have just now that could benefit from the very low Rds(on).
I've seen it done before, though. I built my first hi-fi amp using dual die lateral MOSFETs from Semelab.
The datasheet claimed double the power dissipation, but the case-to-heatsink thermal resistance means that the real world improvement is more like 50%. Probably not so much of an issue in a switched mode design.
Alex M
Sun Feb 26 2012, 09:18AM
Dat gate capacitance...
Sun Feb 26 2012, 10:21AM
Let me guess, it's twice as big as you expected? tongue
ConKbot of Doom
Sun Feb 26 2012, 03:28PM
I thought things like "hex fets" and whatnot were just large arrays of paralleled FETs already?
Electra
Mon Feb 27 2012, 11:41PM
What I don’t understand is how or why they put like 100+ amp rated devices in
TO-247 packages? The leads or PCB traces will surly get hot enough to melt the solder or fail themselves wont they? Unless there’s typically another way of mounting them that I’m not aware of, unless they expect nobody will use them at more than a third of their maximum rating or something, or perhaps it’s just for repetitive pulse rating.
hboy007
Tue Feb 28 2012, 12:32AM
P_diss is 429W (derate by 2.86W per K (T(°C)-25°C)),
leaving you with 143W at boiling hot 125°C which sounds very reasonable to me.
Tue Feb 28 2012, 07:42AM
The legs of a TO220 or TO247 can carry a surprisingly high current density, because they're short, and can lose heat into the PCB (or whatever they're soldered/clamped to)
Also as pointed out, the maximum current listed on the datasheet is thermally limited with a case temperature of 25c and can't be sustained in the real world with a sensibly sized heatsink. For reliable and efficient running, you would use those "100 amp" MOSFETs at maybe 30A RMS.
Nicko
Tue Feb 28 2012, 09:03AM
Alex1M6 wrote ...
What do you expect ? its all about compromise - the raw physics involved in getting a low RDSon means a big gate (or two). Gate drivers are well understood and cheap, so Qg should not be a problem if driven "stiffly" by an appropriate chip.
Not very expensive though - about USD 3.60 from Digikey - RS & Farnell don't seem to have them...
