  • Guests: 57
RoV IW3IPD (63)
01/13 si2030 (62)
How to trigger HV transformers
thegreat
Sat Feb 25 2012, 09:56PM Print
thegreat Registered Member #2942 Joined: Fri Jun 25 2010, 06:29PM
What I am really wondering is, how do they trigger a HV transformer to make a spark gap? For example, in t@ser guns, as far as I know, last HV coils (t2) primer is triggered by ~1000 volts with the help of a capacitor. What I dont understand is, how do they discharge a charged capacitor over the HV coil? With transistor???
Pinky's Brain
Sat Feb 25 2012, 10:11PM
Thyristors, IGBTs, MOSFETs, BJTs, tubes, triggered spark gaps ... almost everything which can switch high voltages has been used to discharge capacitors through high voltage transformer primaries at one time or another.
Alex M
Sat Feb 25 2012, 11:13PM
Usually its by a spark gap. Just like a spark gap tesla coil, the capacitors get charged up then the voltage across the gap is enough for the current to "jump" the gap creating a pulse of DC through the primary coil and creating a spark on the high voltage secondary coil. Timing can be controlled by the size of capacitor and spark gap distance.
It is how I made my homemade shocker anyway, I used a 0.047uF 2kv cap and a homemade step up transformer. The small internal spark gap was made using a piece of strip-board and the small gap between the traces. Works quite well. Powered by 2x AA battery's.
thegreat
Sun Feb 26 2012, 12:21PM
I am beginging to understand.but still confused...Can someone please tell me how this works???
Especially how spark gap pulse circuit works? I cannot see any component there. just conductors :S
Alex M
Sun Feb 26 2012, 12:27PM
This should explain it Link2
Pinky's Brain
Sun Feb 26 2012, 12:54PM
wrote ...
how this works???
Unreliably in the long term? That spark gap doesn't seem like it will keep a very constant breakdown voltage.
thegreat
Sun Feb 26 2012, 02:29PM
Alex1M6 wrote ...
thanks for the info. I see some diodes upper left side of this image.
What is it? Voltage multiplier? if so, how does voltage multiplier work with dc voltage?
Pinky's Brain
Sun Feb 26 2012, 05:15PM
If they are connected as in the schematic in Alex's link then they are simply rectifying diodes for a flyback converter, put in series to increase the voltage rating, and not a multiplier at all ...
