  • Guests: 73
Flyback driver eating 555 timers
ZakWolf
Tue Feb 21 2012, 09:40AM Print
This flyback driver has killed 6 555 timers why? Link2
I can draw a good size arc for about 3 sec then it dies
Daedronus
Tue Feb 21 2012, 09:50AM
the 555 is the only thing killed?
is the mosfet still working?
if the gate on the mosfet is shot the 555 will go next.
ZakWolf
Tue Feb 21 2012, 09:55AM
When the first pot is at its max or minimum and i turn the second one the same i can draw a tiny 1/2" arc, but if turn the first one back the other way it instantly fry's.
The mosfet is ok, im using an irf250.
ZakWolf
Tue Feb 21 2012, 09:58AM
Are pin 2 and 7 connected?
Wolfram
Tue Feb 21 2012, 10:21AM
That circuit is completely wrong. The flyback is connected directly across the DC supply and the 555 timer is grounded to the drain of the MOSFET that it drives. I would be surprised if it did anything at all the way it's drawn, so I guess you fixed these errors when you built it.
Even with these errors fixed, it's not a very good circuit. You're probably killing the 555s with spikes on its power supply. Either power it from a separate supply or use a 12V regulator before it. The best solution is to build a better circuit, like this Link2
Daedronus
For a 555 personally I would use this schematic:
from here:
ZakWolf
Tue Feb 21 2012, 10:44AM
Thanks everyone
ZakWolf
Wed Feb 22 2012, 04:09AM
I added the filter cap to stop the spikes, problem solved . now i just have crazy heating in the mosfet
