  • Guests: 99
01/12 RoV IW3IPD (63)
Identifying HV items
mihlikos
Tue Feb 21 2012, 03:15AM Print
mihlikos Registered Member #3947 Joined: Mon Jun 13 2011, 11:06PM
Some items are into my possession and need to know the specs and what are they.
First is this capacitor.
First time i see capacitor with 4 connections.On the big pair is written H1, H2 and on the small pair is written L1, L2
I tried to find information online but with no result.
My questions are
1)is this a pulse capacitor ?
2)Is this 2 capacitors in one ? One pair of connection (the smal) is 80kv 00.1mf and the other (the big) is 100kv 00.1mf ?
3)Can this type used for AC assuming the voltage is lower from the spec ?
1329794084 3947 FT0 Dsc04813
1329794084 3947 FT0 Dsc04819
1329794084 3947 FT0 Dsc04820
Forty
Tue Feb 21 2012, 03:23AM
It might also be two 0.01uF 80kv capacitors with a 100kv surge rating. I'm not sure if it is a pulse discharge capacitor but it certainly has the look of one.
have you tried looking up that 9 digit code at the bottom?
GrantX
Tue Feb 21 2012, 05:12AM
2 pulse capacitors I have use a large insulator for the positive connection and a small insulator for the negative, so I'd guess that on your capacitor the large insulators are the positives the the small middle connections are for the negatives. I agree with Forty that they are probably both 80kV, with a 100kV surge rating. Not sure how it would go on AC, but if you at least halved the input voltage I don't think it would harm it.
mihlikos
Sat Feb 25 2012, 12:55AM
Thanks, your correct.I made a test and the small insulators poles is the one end of the caps and the big insulator poles is the other end.
The next item that i have some questions about is this xray transformer that it have too many wires.
What i can understand is that there are 3 pairs.The input pair (3,4) and 2 output pairs (1,5) and (2,6)
The questions are,
a)What are the wires 7 and 8 ?
b)Do i connect 5 and 6 together and ground it?
1330130293 3947 FT134613 Dsc04838
1330130293 3947 FT134613 Dsc04840
1
Wolfram
Sat Feb 25 2012, 01:20AM
Yeah, connect 5 and 6 to the core. Both these wires need to be grounded to the core at all times when you're using the transformer, otherwise you could risk an arcover between the inner turns of one of the secondaries and the core, which would most likely ruin the transformer.
teravolt
Sat Feb 25 2012, 03:03AM
this transformer has two outputs 180 deg out of phase 1,2.
5,6 are a single turn wire for current mesurement? 7 is electrostatic shield and 3,4 is the primary.
Adam Munich
Sat Feb 25 2012, 05:52AM
7 and 8 are most likely grounds of some sort, probably a shield between the the primary and secondary.
