  • Guests: 73
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Having trouble with audio modulating 555
Platinum
Mon Feb 20 2012, 07:23PM Print
I'm trying to audio modulate a flyback with pin 5 of a 555, I got it working, then I broke my brothers MP3 player (to scared to use my computer) when I put audio in pin 5 my power supply pulls too much current and goes off, but normally it won't do that unless I stretch the arc to much, so what can I do?
Sorry if I not making sense, thanks.
haxor5354
Mon Feb 20 2012, 07:45PM
did you atleast put a capacitor in series with the MP3 output to pin 5?
Platinum
Mon Feb 20 2012, 09:37PM
Yes.
Alex M
Tue Feb 21 2012, 01:55AM
Platinum wrote ...
Same thing used to happen when I was messing around with the crappy 555 driver, as soon as audio modulation was added current draw went up to around 10.5 amps.
Do your self a favour and make a half-bridge if you want audio modulation as the 555 driver is an endless source of frustration and time wasted.
Platinum
Tue Feb 21 2012, 02:33PM
I have two irfp640's so I'll have to make a half-bridge with what I have, where is the schematic?
I won't build it just yet, I will have some more arcs with the 555, it spray alot, but with my current flyback it does not.
I do not have alot of components to make circuits, so what would be the best to make?
Thanks.
For a halfbridge I have opened an old ATX supply, I got a SG6105D, a CEP603AL N-channel enhancement FET, and two C5763 power transistors.
