  • Guests: 35
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Filtering power supplies...
NoName
Mon Feb 20 2012, 07:14PM Print
NoName Registered Member #4451 Joined: Fri Feb 17 2012, 05:51PM
Typically, I would power a microprocessor circuit with something like the 5V 7805 voltage regulator. I would also decouple the inputs and the outputs with 0.1uF caps. I also put a 22uF tank cap for filtration.
Well, my most recent project is a flyback converter. Works great, but I notice when it starts charging, I get a jitter and some flashing on some LEDs off the microchip. I need to add a zener on the regulator in case I pump to much voltage back into the circuit. But, I wonder if I am having a dip in current when the converter kicks on. What do you guys use as caps on your IC circuits? Im thinking maybe I need somethin bigger so I have more room for spikes and reserves.
radiotech
Mon Feb 20 2012, 07:22PM
The common return for the LEDs should be looked at to see if it shares
a 'soft' ground return path.
Apart from the flickering of the LEDs, does the processor execute properly?
NoName
Mon Feb 20 2012, 07:55PM
Yes, the procressor works fine. Strange. Maybe an over voltage?
radiotech
Tue Feb 21 2012, 04:03AM
Did you write the program for the processor that controls the lamps?
If so, are they switched by logic that chanes quickly?
