  • Guests: 68
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
diode bricks and questions
haxor5354
Sun Feb 19 2012, 12:31AM Print
just bought a BEEFY diode brick for 5 bucks. MUR10020CT
seems to work when I tested it with a multimeter
on the datasheet it says 40v RMS, does it mean it can only safely rectify 40 volts AC without self destruction?
and what are fast recovery diodes for?
Daedronus
Sun Feb 19 2012, 01:36AM
Fast refers to the recovery time, the time it takes the diode to switch from forward conduction to blocking. While in the recovery time the diode acts as a conductor. This usually means we have a short.
When rectifying high frequency AC we need a fast diode or we will spend too much time (% of the cycle time) in the recovery zone.
If we use slow diodes with a HF AC we get higher losses and possibly EMI noise because of the current spikes while the diode conducts in reverse.
To sum it up, the most common place to find them is in the rectifying stage after a transformer in switched mode power supplyes, since they work at high frequency.
hboy007
Sun Feb 19 2012, 12:39PM
This is what reverse recovery looks like:
a schematic illustration looks like this
reverse recovery characteristics also degrade with increasing temperature.
The importance of
* reverse recovery time trr
* stored charge Qrr
* temperature dependency
is for example reflected in the R (equilibrium) and C (transient symmetrization) values needed to symmetrize a series arrangement of power diodes
(where n is #diodes in series, Ur rated voltage, Um max. desired voltage across the network, dQrr is the max. deviation of Qrr for any two diodes over the full temperature range)
So fast diodes with soft recovery (no snapping) and ultra low Qrr are desirable. SiC Diodes are the most superior ones that currently begin to enter the market.
I hope that helps in comparing your diode to others and in getting an idea what your datasheet says.
