  • Guests: 33
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Laser power control - help me design a servo attenuator
hboy007
Sat Feb 18 2012, 10:39PM Print
I'm currently working with Nd:YAG and Nd:YAG pumped Ti:Sapphire lasers. I use them to optically excite quantum dot samples. My current goal is to perform pulsed and CW power dependent measurements. Unfortunately, the 532nm pump power is only stable to within a few percent and fluctuates on a timescale of 1-10 seconds and the CW output of the Ti:Sa is even worse (make it 20-95%).
Therefore, I'd like to build a motorized attenuator that autonomously controls the output power to within <1% around a safely reachable level. Perhaps someone can look over the parts selection I've already made? That would really save me some time. There's nothing like getting it right the first time.
The idea is to insert a linear graded attenuator and two glass plates (single side wideband AR coated) into the beam. All elements will be tilted at a small angle to compensate for beam shifts (the reflection of the attenuator won't be usable for monitoring so both glass plates are tilted in the opposite direction to the attenuator).
Here are my ideas:
* use a reflective graded ND filter 10x50mm Link2
* I've obtained a Minebea 14PM-M201 Link2 stepping motor (35x35x20mm, rated 12V, 1.8°/step)
* L6219 Link2 will be used in conjuntion with the motor, allowing easy microstepping
* an ATMega16 Link2 will do for a main controller
* an FT232 Link2 will provide easy connectivity for configuration via UART
As for the intensity measurement before and after the attenuator,
* two BPW34 Link2 photodiodes with frosted glass attenuators (frosted microscope slides! Link2 ) in front of them will be used.
The PDs will be used in low-noise, low speed photovoltaic mode, so the opamp choice for the PD front end won't be critical.
* MCP6S22 Link2 seems to be a good choice to implement gain control for the ADC since the microcontroller ADC also multiplexed. Wouldn't it be good to sample both PDs at once with a sample&hold circuit, then digitize both channels sequentially? I would end up with two MCP6S21 and one HEF4066 quad bilateral switch. Add some jFET opamps like TLC084 Link2 for buffering.
The whole system will be designed to fit the Linos microbank system (or Thorlabs cage system, nevermind).
Linear guide rails for the filter are a thing I'll have to figure out how to implement in due time. I like the way the engineers solved this problem with chrome steel rods and brass bushings in optical drives (just google KEM-400AAA for a neat example) ...
Sorry if the above was a little incoherent, I just wrote it down in one go. All comments are welcome!
radiotech
Sat Feb 18 2012, 10:50PM
Would a Pokels cell be of use ?
hboy007
Sat Feb 18 2012, 11:00PM
Pockels cell intensity modulators like Link2 do exist and we also have Pockels cells. Since funds are limited and the power control feature is regarded as a nice-to-have, I'm not sure if this nice solution is within reach. The pockels cells we have will most likely be used in other parts of the setup (e.g. for time slicing for time-resolved measurements, Link2 or in other experiments.
Sun Feb 19 2012, 08:12AM
In situations like this I prefer to take a step back and look at the fundamental problem. Why is the pump power unstable in the first place? Does the instability have higher frequency components that a motor would be too slow to correct?
To take an example, the pump laser could possibly be stabilised with feedback from a photodiode into the driver. Maybe it already has that feature but it's broken :) Or maybe not so easy if it's an ancient Nd:Yag pumped by filament lamps.
And to take another example, some lasers naturally emit in the form of chaotic bursts of light, maybe the Ti:Sapphire is one of them when you try to run it CW?
Shrad
Sun Feb 19 2012, 09:02AM
this should be stable
the problem seems to be your pump laser
what is the type, brand and age?
you should stabilize the pump power and quality
do you have a vibration free beamtable? a Ti:Sapphire laser is very sensitive to vibrations if it is in a Z-fold cavity
also, what are power levels in your setup? 532nm pump power should exceed laser trashold of the Ti:Sapphire by some extend to get decent stability
it is also extremely sensible to temperature drifts, even the smallest, so you should use a liquid cooled mount for the Ti:Sapphire along with a nice chiller (needs a decent regulation) and you need to put your sapphire cavity inside a boxed beamtable with no or near no water vapor (an aluminium box with windows and a plexiglass cover, filled with CO2, will do)
hboy007
Sun Feb 19 2012, 12:15PM
Allow me to give you a little more information about the setup:
The main laser is a Coherent Verdi V10 Link2
"Verdi lasers are “smart” in that they have feedback
loops which can automatically adjust the diode drive
current to maintain the power at a constant value.
Monitoring the drive current is one way to track the
overall health and efficiency of the laser. "
There are indeed some power levels where the output is smooth over time. I haven't characterized the behaviour of the internal feedback loop at all power levels but the laser should run stable at as low as 100mW.
I also operated it at 1.5W with roughly proportional power fluctuations.
When pumping the Ti:Sa Link2 , we use around 8W @ 532nm, producing 1.5-2W QCW in the 800-850nm region.
The whole setup is bolted down onto an actively damped optical table, both lasers are cooled in series by a Thermo Scientific Accel 250 chiller. There used to be another chiller that was installed for the last couple of years with some crumbs and blue-greenish residue in it. Clogging of the lasers did occur and I must assume that my colleagues did a proper cleaning in the course of this.
There won't be a way to purge the Ti:Sa housing with CO2 since the lab does not provide proper ventilation to ensure safety in this case.
Carbon_Rod
Sun Feb 19 2012, 11:26PM
The TEC units can still cause stability issues depending on the age of the laser.
The excitation cavity monitor diode method may not completely stabilize the DPSS output.
DVDR drives typically use a miniature Liquid Crystal Variable Retarder with a closed-loop optical power sensor on the output (or a splitter):
Cheers,
hboy007
Sun Feb 19 2012, 11:59PM
LC retarders would be a fine option and I recall we also have one or two of those somewhere. Beam splitter and polarization optics won't be a problem - but can the LC units handle 200-500 W / cm² ?
Something for the "ideas thread": make a variable laser attenuator out of active shutter glasses with the filter removed
Carbon_Rod
Mon Feb 20 2012, 08:12AM
Higher power setups usually already have one optical isolator to protect the driver.
I'm not sure if these would even put up with the output levels if you are still exceeding 500 W/cm^2 over a 20cm^2 approximate area ( 2" LC unit). Most LC units have a lower damage threshold of 500 W/cm^2 in CW mode.
After filtering the DPSS output for the wavelength you are after, the power level will usually be around 60% - 80% of the pump laser under ideal circumstances.
At $2k each, it would be advisable to double-check your exact part number for safe operating area ratings. wink
Mon Feb 20 2012, 12:23PM
Could the exposure control system of a good DSLR be of any use?
