  • Guests: 62
RoV IW3IPD (63)
01/13 si2030 (62)
Power supply question
Raka
Sat Feb 18 2012, 08:21PM Print
Raka Registered Member #1838 Joined: Tue Dec 02 2008, 06:01PM
Im driving a stepdown transformer with a halfbridge. The duty cycle of the halfbridge is controllable in order to vary the output voltage of the transformer. Problem is that the dc stay at max because during the time a transistor is switched off the inductance of the stepdown transformer keeps the current flowing through the freewheel diodes and thus I cant get voltage regulation without a heavy load on the output.
What can i do to regulate the no load voltage of the output
Daedronus
Sat Feb 18 2012, 09:48PM
Do you have a rectifier, inductor and capacitor after the transformer?
Sat Feb 18 2012, 10:29PM
You got it. Voltage regulation by PWM won't work without an inductor on the secondary side.
Even with the inductor, the regulation won't work too well at currents lower than the continuous current transition. That's why there are many SMPS that won't work with no load.
Raka
Sun Feb 19 2012, 07:31PM
So that is what the inductor in the designs are for. I thought is was to filter out rippel. Hence, I didn’t experimented much with inductor values in the test circuit.
Thanks for helping
