  • Guests: 58
555 driver very hot
Platinum
Fri Feb 17 2012, 07:53PM Print
at 19v input (10vdc into 555) the TVS I think, gets very very hot it's a perfect circuit, not even built by me, what's causing the zener to get steaming hot (after 10 seconds, it'll start to melt solder)...
Please help.
Thanks!
m4ge123
Fri Feb 17 2012, 10:11PM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
What circuit are you using?
Platinum
Fri Feb 17 2012, 11:15PM
MOSFET is OK, 555 is OK, I have spare 555 and MOSFET, TVS was very very hot, now the circuit outputs very low spark not even a mm, So I think TVS is dead, because it can't be a resistor or capacitor...
Fri Feb 17 2012, 11:59PM
Platinum wrote ...
whats the voltage rating in the datasheet for Z1? Can you post the datasheet please...
Platinum
Sat Feb 18 2012, 12:09AM
This sheet will do.
Sat Feb 18 2012, 12:11AM
Platinum wrote ...
This sheet will do.
so which TVS is yours?
Platinum
Sat Feb 18 2012, 12:12AM
1.5KE440, not sure of manufacturer.
Sat Feb 18 2012, 12:36AM
so the highest continous (working) voltage is about 356.... hmmm.... let me think....
what transformer are you using? how many turns?
Platinum
Sat Feb 18 2012, 01:03AM
Large DC LOPT 20turns. My only flyback that doesn't explode on ZVS.
Sat Feb 18 2012, 01:10AM
remove the component called Z1 and make sure D1 is good.
what transistor is Q1? post its datasheet.
