  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Capactor with different plate lengths.
Andy
Thu Feb 16 2012, 02:46AM Print
Hi , If you have a capactor with one plate which is square and whole, and the second plate is lots of turns of insulted wire, would there be a increase of volts from whats powerinf it?
Wouldn't the charge have to move more distance on one plate as the second
radiotech
Thu Feb 16 2012, 05:18AM
Perhaps this is the answer you seek.
If two plates of capacitor that is charged to a certain voltage are moved apart,
the voltage between the plates will increase.
You could look up 'electrophorus' .
Andy
Fri Feb 17 2012, 04:12AM
more like this
radiotech
Fri Feb 17 2012, 06:01PM
The answer is yes, depending on the areal (three dimensional)
implementation of your sketch.
If a capacitor and and an inductor were connected such that the charging
current flowed through the inductor. when an alternating current is
considered, there would be higher voltages across each part, than was
applied to both, when the reactances were equal.
