  • Guests: 92
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Plasma Pencil
AleSeg
Tue Feb 14 2012, 03:15AM Print
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
Hi.
Is it possible to do a "plasma pencil" at home ? What do you think?
I think it's easier than a lot of works done before in this place.
Article In Wikipedia
Youtube video
Bye
jpsmith123
Tue Feb 14 2012, 03:35PM
Hello AleSeq,
I think it's possible to make it at home, although you might need some machining work done and some experience working with RF/microwaves may be helpful.
I've seen several "plasma pencil" type devices that are said to operate at atmospheric pressure, but IIRC, they all needed to use at least some argon or helium gas mixed with air. So my main question is: does anyone have a successful design for a device that operates using just air at atmospheric pressure? If so, I would be interested in making one myself.
I looked at the Adtec web site, but unfortunately their site does not seem to have any information on the design and construction of their plasma torch (as demonstrated on the you tube video you've linked to for example).
Maybe they've got some patents you could examine. I usually try to look for patents at this place: Link2
Let me know if you find any more info.
Ash Small
Tue Feb 14 2012, 04:50PM
jpsmith123 wrote ...
The wikipedia link above mentions a paper on the subject. I tried googling it, and found several others. Unfortunately, all the links I found were 'subscription only'. Maybe someone could sign up for a 'free trial' and download three of them and post details (or maybe someone here has a relevant subscription already, and could maybe enlighten the rest of us?)
EDIT: it appears to be a capacitatively coupled plasma, at a frequency in the kH, but with nanosecond pulses, from what I was able to read on the subject. It also mentions that helium is the gas of choice. (I was able to read the first page of one article)
Pinky's Brain
Tue Feb 14 2012, 06:04PM
Ozone production is probably the reason why air isn't used in medical applications, also it's possible that ion species die out faster in air.
That said simply blowing air through a tube with electrodes on both sides, and insulation to make sure there are no external arcs, with a high AC voltage between them should generate plasma species (this is Double Barrier Discharge).
jpsmith123
Tue Feb 14 2012, 07:29PM
I found a patent for the so-called "plasma pencil". I didn't have time to read it yet, but just skimming through it, it looks very simple.
Tue Feb 14 2012, 07:37PM
Absence of ozone production (as suggested by Pinky above) and room-temperature plasma temperature are the reasons given for choosing helium given in this letter:
Appl. Phys. Lett.
87, 113902 (2005)
Room-temperature atmospheric pressure plasma plume for biomedical applications
M. Laroussi and X. Lu
As low-temperature nonequilibrium plasmas come to play an increasing role in biomedical applications, reliable and user-friendly sources need to be developed. These plasma sources have to meet stringent requirements such as low temperature (at or near room temperature), no risk of arcing, operation at atmospheric pressure, preferably hand-held operation, low concentration of ozone generation, etc. In this letter, we present a device that meets exactly such requirements. This device is capable of generating a cold plasma plume several centimeters in length. It exhibits low power requirements as shown by its current-voltage characteristics. Using helium as a carrier gas, very little ozone is generated and the gas temperature, as measured by emission spectroscopy, remains at room temperature even after hours of operations. The plasma plume can be touched by bare hands and can be directed manually by a user to come in contact with delicate objects and materials including skin and dental gum without causing any heating or painful sensation.
Tetris
Tue Feb 14 2012, 08:10PM
I thought plasma was extremely hot?
Pinky's Brain
Tue Feb 14 2012, 09:38PM
Equilibrium plasmas are hot. Non equilibrium plasmas can be cold, aka non thermal plasmas.
Ash Small
Tue Feb 14 2012, 10:14PM
I imagine this is why it uses nanosecond power pulses at kH frequency, which accelerate the electrons much more than the ions, thus giving high electron temperatures while the ions remain 'cold'.
The ions account for the vast majority of the mass, so the overall temperature rise is negligible, but I'm only guessing here.
Pinky's Brain
Tue Feb 14 2012, 11:45PM
Microdischarges from a barrier discharge will do the same thing (because you can just use a normal AC voltage it is one of the easiest way of creating non thermal plasmas). Maybe they use pulses because a sine wave will put a little more thermal energy into the gas from dissipation? Or alternatively, it could just be a patent issue.
